spark plugs and their gap, plug wires
Old 29 Aug 2011, 10:58 pm
Default spark plugs and their gap, plug wires
Hi Folks.......before I get flamed......I cant find on the board what are the best plugs and wires to use with an 06 Turbo Cruiser. I know the info is there someplace but I cant find it.....sorry. The other question is what do I gap the plugs at????? I read that the Chrysler gaps are wrong.........
Thanks folks.....
Bill
Old 29 Aug 2011, 11:31 pm
Kawizx9r's Avatar
Default Re: spark plugs and their gap, plug wires
On a completely stock vehicle, I'd run .035 gap.
As far as what plugs, I've always used NGK coppers (4306) and replaced them every other oil change. I know it's a bit extreme but they're not expensive.
As for wires, anything is better than stock. I personally chose Taylor 8.2's when I modded my PT GT.
PS Don't use platinum spark plugs on a turbo PT.
Kawi is a friggin genius!
Old 30 Aug 2011, 02:01 am
On a stock vehicle I'd use the stock copper plus plugs at a .040 gap. It is recommended on my Stage 2 (srt-4) kit to run a .035 gap so I wouldn't run it on a stock vehicle. I like the MSD wires on both my stock GT and my srt.
Old 30 Aug 2011, 01:43 pm
Gremlin's Avatar
Why not use the platinum plugs?
White '03 GT. Mine since 2010. DIY work (read, budget): DIY cabin air filter, ball joint/control arm bushings/wheel bearing replacement, CV axle replacement, brakes, struts, K&N drop-in filter, oil pressure sensor replacement, Spark plug gasket replacement.
"But I don't want to go among mad people! Alice remarked. Oh you can't help that, said the cat, We're all mad here. You're mad, I'm mad. How do you know I'm mad? asked Alice. You have to be, or you wouldn't have come here, replied the cat."
Old 30 Aug 2011, 02:23 pm
Kawizx9r's Avatar
It's a following everyone goes by in the PT-Turbo and SRT-4 community....no but really, don't use them.
Platinum plugs are meant for durability, not performance. Don't expect it to perform as well as the slightly less expensive copper equivalent.
If you want durability, I suggest NGK Iridium plugs otherwise go with NGK coppers.
PS If your car is a GT and not a turbo-lite, I hope you're using 91/93 OCT fuel.
Full synthetic only, regardless if it's a GT or Turbo-lite.
No boosting in 4th gear (OD) if you've got an automatic.
Old 31 Aug 2011, 07:25 am
There are reports that the way the platinum is bonded on breaks down in heat of turbo engine and the tip copmes off....
Old 30 Sep 2011, 10:49 pm
dsmturbo's Avatar
Send a message via MSN to dsmturbo Send a message via Skype™ to dsmturbo
Can you tell me what part # the Taylor wires are? I have been looking here for some?
Old 01 Oct 2011, 12:14 pm
man get the granatelli's from modern performance
Old 01 Oct 2011, 12:28 pm
dsmturbo's Avatar
I would but I am in Canada and I believe they only ship UPS and USP screws us on brokerage handling fees.
Old 01 Oct 2011, 04:59 pm
I've ordered plenty from Modern Performance and no issues with this whatsoever.
2004 GT, 5spd, Stage1, K&N FIPK, Magnaflow 2.5" Catback, 3" O2, 3" Needswings Catless DP, Mopar BOV, NGK Iridiums, Mopar Wires, Aeroforce Interceptor w/wideband kit, Vibrant Catch Can, Prothane Inserts, AMX1397 upper and lower pipes, Plastic Intake, Hurst STS, S2 WGA, Factory Sub and now Alky Injected!
Spark pulgs and spark plug wires? balvarez814 Tech & Performance Forum 1 13 Aug 2008 08:16 pm
spark plug wires dzinman Tech & Performance Forum 1 28 Jul 2005 01:25 pm
spark plug wires Nudle Tech & Performance Forum 9 14 Sep 2004 06:00 pm
Spark Plug Wires what should I do? KingKole02 Tech & Performance Forum 17 12 Jan 2004 11:06 am
spark plug wires OurPTGT General PT Cruiser Discussions 3 06 Mar 2003 05:05 am
