Non Spooling Turbo
Old 04 Oct 2011, 04:54 pm
Default Non Spooling Turbo
Over the past few weeks I have changed practically every sensor on my 2006 PT cruiser turbo; each time I solve one error code, another arise. Today while driving with (NO) error codes/check engine light showing I attempted to push the issue and do a quick acceleration. This experiment led to more issues, when I pressed the gas and the tach rose above 3.5, the engine started to make an odd sound like a motor cycle missing. Spoke with a couple people and they stated the car rev limiter engaged, which meant the turbo is not responding or working. Have anyone had this experience? Also, the last code on the car was P2074, which disappeared when I installed the position sensor, but returned when I attempted the fast acceleration. To date, I have changed the following sensors: MAP, TIP, TPS, 02 (both), new wires, new plugs, fuel injection cleaning, and air breather (all over the past 3 days). Any thoughts/suggestions would be appreciated.
Old 05 Oct 2011, 10:28 am
Default Re: Non Spooling Turbo
What did you gap plugs at? Should be no larger than 0.040.
Did you buy Mopar sensors?
mopar parts online - Google Search
Many aftermarket sensors don't work on the PT.
Old 05 Oct 2011, 04:41 pm
All the sensors were purchased from chrysler, but the plugs installed were gapped at .50 as stated on the label under hood--should they be .40?
Old 06 Oct 2011, 12:13 pm
Some even recommend smaller than 0.040. I believe the 0.050 was replaced by a tech service bulletin to 0.040.
Not sure that's your problem, but shouldn't hurt anything, either.
Turbo stuffs Manifold srt4 stage 3 SMT6 Turbo t3t4 50 trims and more bobgt Classifieds: For Sale/Trade 1 10 May 2010 02:29 pm
Colima Pro Street Shadow Turbo VS PT Cruiser Turbo skylight PT Cruiser Videos 5 31 Dec 2008 03:21 pm
Difference btwn Turbo & Non-Turbo Wheels tom-t-rifik Turbo Wheels/Suspension/Handling 6 12 Jun 2004 11:40 am
180HP turbo lite and 215HP turbo difference. alceryes General Turbo Discussions 27 29 Dec 2003 01:57 am
Ditch the wimpy 'Turbo' insignia on your PT Turbo CraigO Exterior & Interior Styling 18 12 Aug 2003 03:07 pm
