1/4 mile launching techniques
  #11 (permalink)
Old 13 Jan 2004, 12:40 am
not very
2003 Dream cruiser 2 #1434
mopar bov and k&n drop in filter ,billet shorty antenna, silencers removed, custom painted rear shelf that says\"Dream Cruiser II\"and maybe, doubtfully soon------stage 1
  #12 (permalink)
Old 13 Jan 2004, 02:26 am
well, i am at 30K and have NO clutch problems. I wouldn't suggest doing it out of every light, but for a weekend warrior it shouldn't pose to many problems. But it all depends on the driver of course.
My Cruiser is slow. I love the law.
  #13 (permalink)
Old 13 Jan 2004, 08:56 am
You do not need to let off the throttle to shift with Stage 1 ("power-shifting")with the 5-spd. You lose precious tenths of a second by letting off the throttle between shifts although it IS harder on your drivetrain to do so. I leave between 2000-2400 RPM also and slip the clutch. Leaving harder than that usually produces wheel-hop. According to the SRT4 forums changing the upper motor-mount ( or all motor-mounts AND tranny mount)to a firmer poly motor-mount helps cure the wheel-hop problem. I purchased a firm upper-mount but have yet to install it since the drag-tracks around my area are closed until spring.
It will be really interesting to see how our Cruisers will be able to get the power to the ground with S2 especially if we're lucky enough to get the "Toys" and the additional 15 HP the Toys bring (race-fuel switch). On my best run so far (14.90 ET) I spun in first and second gear and even chirped the tires in 3rd. (power-shifting)...what's another 30-45 HP going to do? Chirp the tires in 4th??? This should be a really fun summer...BRING ON S2!
MEXICANPT, what tire pressure where you running? Most Cruisers and SRT4's are getting best results running 23-25 lbs. air pressure in the front (stock tires) at the track.
Deen
  #14 (permalink)
Old 13 Jan 2004, 10:35 am
Send a message via AIM to macster
quote:On my best run so far (14.90 ET) I spun in first and second gear and even chirped the tires in 3rd. (power-shifting)...what's another 30-45 HP going to do? Chirp the tires in 4th??? This should be a really fun summer...BRING ON S2!
Deen
Uhh Deen
RE" best run so far" you list (14.90 ET) but your signature states 14.40, so which is it? As far as launching I'm with you, the RPM's on the launch are critical. It very important to find that RPM range that you launch at and not spin. For me (autostick) its about 1500 RPM)
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
  #15 (permalink)
Old 13 Jan 2004, 03:30 pm
quote:Originally posted by MEXICANPT
I'll try all of this, one more thing though, how many miles will my clutch last if I do this often?
Do you mean often as in every stoplight or often as in weekend warrior? While any time you slip the clutch it will wear more, if you just make a couple of runs on a weekend yuur clutch should still live a long and happy life. Maybe not as long as your abuela's clutch, but still acceptable.
  #16 (permalink)
Old 13 Jan 2004, 07:46 pm
I plan on doing it every other weekend, so that shouldn't be a problem.
Patriot Blue 5-Spd, Stage I, Mopar BOV, BTG Intake, Custom 3\" Turbo-Back, Spring Mod, BTG Shock Tower Brace, Vogtland Springs, Koni Shocks, Eibach Sway Bars, Azev Type M 18x8.5 wheels, Ventus K104 tires, Projector Bi-Xenon Lights, Rear spoiler, Autometer Gauges, Illuminated sill plates, K&N Oil Filter, Mopar subwoofer. Mexico City. See pics: http://www.sportcarsforum.com/forum/viewtopic.php?t=715
  #17 (permalink)
Old 13 Jan 2004, 09:03 pm
My PT is my first car with a 5speed so i was just wondering exactly what "slipping" the clutch meant?
Set the geere shift for the high gear of your soul!!!
http://interactive.colum.edu/students/jsoltes/IMP/projects/project%201/ptperform.html
  #18 (permalink)
Old 14 Jan 2004, 03:59 am
Send a message via AIM to 026TB4U
letting the clutch out only part of the way momentarily and then releasing it fully. ie; 1/4 ofthe way then half the way 3/4's and then all the way. insterad of just reving and releasing.
stage 1,manual bleed valve(18psi), k&n drop in , silencer removed, mopar bov and oh yeah its totalled now, waaaah
  #19 (permalink)
Old 14 Jan 2004, 06:45 am
McMaster,
Woops, guess my fingers got ahead of my brain. 14.40 ET is my best so far and that was using the "spring trick" with S1
Deen
  #20 (permalink)
Old 14 Jan 2004, 08:47 am
quote:Originally posted by hyracer
McMaster,
Deen
Deen
Can you post a picture of that? I'd like to see one just for info, Man that's a nice time, with the S2 you should be in the 13's. Actually, I can see 12's for this puppy high 12's and streetable.
seriously
macster
Don\'t help me
Help the bear
5,000 vs. 3,000 mile oil change? zzzhuh General PT Cruiser Discussions 13 31 Mar 2004 10:02 pm
Suspension Techniques Sping Install LAF Turbo Wheels/Suspension/Handling 4 05 Jan 2004 07:08 pm
dodge stealth 1/4 mile times 026TB4U General Turbo Discussions 13 24 Dec 2003 06:14 pm
1st time w/Stage 1 on 1/4 mile strip PT-Dave General Turbo Discussions 1 25 Oct 2003 11:23 pm
Suspension Techniques Sway Bars For the GT Turbo Gear_Head Turbo Wheels/Suspension/Handling 2 12 Sep 2003 02:51 am
