MEXICANPT...Just Curious...
Old 15 Jan 2004, 08:38 am
Default MEXICANPT...Just Curious...
You said you are able to drive at high speed down where you live. Do you remember how many RPM's you are turning in 5th gear when you reached the speed limiter (130 MPH)? I just remember when I hit 110 MPH one time that I still had a long way to go before reaching redline. Kinda makes me wonder how fast our GT's would go if they weren't speed limited...
Deen
Old 15 Jan 2004, 03:36 pm
The tack shows about 5300 RPM.
I have calculated that we could be doing 149-150 MPH @ 6000 RPM if our cars were not limited.
I can e-mail you a spreadsheet where you can calculate this for both manual and autostick gt's.
Patriot Blue 5-Spd, Stage I, Mopar BOV, BTG Intake, Custom 3\" Turbo-Back, Spring Mod, BTG Shock Tower Brace, Vogtland Springs, Koni Shocks, Eibach Sway Bars, Azev Type M 18x8.5 wheels, Ventus K104 tires, Projector Bi-Xenon Lights, Rear spoiler, Autometer Gauges, Illuminated sill plates, K&N Oil Filter, Mopar subwoofer. Mexico City. See pics: http://www.sportcarsforum.com/forum/viewtopic.php?t=715
Old 15 Jan 2004, 07:16 pm
anyway around the limter??
Old 15 Jan 2004, 07:41 pm
Not that I know of.
Old 15 Jan 2004, 11:15 pm
ok was just curious
Old 16 Jan 2004, 01:08 am
i'm going out a limb here, but how does the PCM know the speed? Could a person "clamp" the speed input to the PCM (if there is one) in the same manner folks do with the MAP sensors? Set it so the PCM never thinks you're running over 110mph or something?
2003 Electric Blue GT
- Greddy E0-1, boost and AFR guages
- Custom exhaust: no muffler, side exit.
- Replaced air box with open end cone filter.
- Stage 1
Old 16 Jan 2004, 02:22 am
I'm not sure, but you might have a point there.
Old 16 Jan 2004, 08:33 am
i not an expert, but if u had ur computer upgraded or reprogramed u should e able to find a way around the limter
we do it in aust all the time i see what i can find out[8)]
PTWHAT!!
Old 16 Jan 2004, 09:21 am
MEXICANPT,
You have e-mail.
Off the top of my head I don't remember where our peak HP occurs...once we get past the peak the Cruiser is not going to gain any top speed...unless we have a tail-wind. Just my 2 cents worth.
Deen
Old 16 Jan 2004, 01:14 pm
I'm not sure, all the cars I've had in the past achieved their top speed past the HP peak.
Question for MEXICANPT... hyracer Turbo Performance 11 01 Apr 2004 12:08 am
Curious ..... onedivinehammer Stage Turbo Kits 8 01 Sep 2003 09:36 am
