error code 0352
Old 09 Nov 2011, 07:14 am
Default error code 0352
hey all m gt is misfiring badly.My snap on scanner told me my coil was messed up,so i replaced it.Nope still misfiring,now my car pulls up o352 ignition coil 2 control circuit?
My wrench is out of town driving my second car so i ,am on my own here.
Anyone able to tell more about this or how to trace this curcuit.
Thank you Rob
Old 09 Nov 2011, 07:33 am
Default Re: error code 0352
Well, here's the diagnostic for that code to trace the problem if you want to go that route.
DIAGNOSTIC TROUBLE CODE (DTC) - P0352 IGNITION SIGNAL COIL B FAULT
I usually try to help with answer from PTDoItYourself.net Chrysler PT Cruiser, PTDIY.net, Do It Yourself maintenance, modification, repair, fix, FAQ, gallery, and tips but in your case it's pointing to going to a professinal for help.
P0352 (M) Ignition Coil Primary # 2 Circuit - Peak primary circuit current not achieved with maximum dwell time.
The Powertrain diagnostic manual indicates the following possible causes for a P0352 DTC:
Good Trip Equal To Zero
Ignition Coil
(A142) ASD Relay Output Circuit
Ignition Coil Driver Circuit Open
Coil Control Circuit Shorted To Ground
PCM
I will assume that if your mechanic had a DRB scan tool and diagnostic manual set in his possession he would have followed up on the fault by performing the tests outlined in the manual. If he did not, there's not much more you can do to troubleshoot this issue on your own other than to locate a shop that has the appropriate diagnostic manuals, equipment and training to use them.
Old 09 Nov 2011, 02:31 pm
Thank you,as always your here for us. Rob
error code... superpug666 Tech & Performance Forum 16 13 Oct 2009 07:33 pm
error codes 0351 0352 1193 partyd General PT Cruiser Discussions 8 29 Aug 2009 03:21 pm
Error Code saldagus Tech & Performance Forum 2 25 Nov 2008 09:51 pm
CPS Error Code smokeydan1 Tech & Performance Forum 16 23 Sep 2008 09:58 pm
Error code??? russ00001 Tech & Performance Forum 0 29 May 2007 04:24 pm
