Twisted turbo shaft
Old 21 Nov 2011, 05:35 pm
Angry Twisted turbo shaft
My 2005 PT Cruiser Touring 2.4 L with Turbo lost power recently. Found the shaft in turbo right behind the exhaust turbine had twisted off. Replaced it with one from salvage yard. This one bent the shaft and the nut came off the end of shaft. I had the turbo rebuilt with all new parts and within 30 miles, the shaft is bent again with the nut missing and the fins messed up. Oil supply line and drain line are not clogged. Computer read-out showed catalytic system, but catalytic converter is not clogged. Any help would be greatly appreciated.
Old 21 Nov 2011, 09:11 pm
tryingbe's Avatar
Default Re: Twisted turbo shaft
Is the compressor bypass valve working?
Unless you can remove the o2 sensor and plug a device there to test the back pressure, you can't say the catalytic converter is not clogged.
85 GLH
Watch out for anchor engine mounts!!
Old 22 Nov 2011, 02:35 am
Chris_TurbosUnleashed's Avatar
Sorry to hear that you are having troubles. Review the PT Cruiser Turbo User's Guide linked below for details on these unique turbochargers.
http://www.ptcruiserlinks.com/forum/...albums229.html
Even though your oil supply line might not be visibly clogged it could still have deposits on the inside walls which will break free and clog the bearing holes. Always replace the line when replacing turbos to avoid future issues. For $30. it is a sound investment.
Don't hesitate to contact us when you are ready to replace your turbo or should you just need further assistance.
Chris-TU
602-76-BOOST
Chris Wright-Owner
Turbos Unleashed, Inc.
Phoenix, AZ Main Office since 1997
Vienna, Austria Europe Office Now Open!
Home of the 2 Year Warranty PT Cruiser TurboCharger
Chris@TurbosUnleashed.com
http://www.turbosunleashed.com
602-76-BOOST
602-76-26678
PT Cruiser Turbo Cam Shaft Navyharley Turbo Performance 22 20 Aug 2015 01:50 pm
03 pt gt turbo shaft question DODGETHIS General PT Cruiser Discussions 1 31 Oct 2011 07:26 pm
cam shaft specs?? bhunt41 Tech & Performance Forum 9 18 Aug 2011 11:07 am
Crank Shaft Russellhold Tech & Performance Forum 5 23 Feb 2010 07:13 pm
Cutting my shaft turbomangt Exterior & Interior Styling 16 23 Dec 2004 12:28 am
