PT Cruiser Forum Car Videos
Custom Wheels
Tailpipe Cutouts
Old 17 Jan 2004, 01:48 am
Mean Green Mean Green is offline
Default Tailpipe Cutouts
I'm going to be getting the Mopar 2 1/2" exhaust so I'm going to have to make a cutout for the right side pipe. What are people doing for the cutout? The trim pieces I see aren't for the turbo cut out and I will need two of them to finish off both cut outs.
Old 17 Jan 2004, 01:50 am
bobs turbo pt bobs turbo pt is offline
my friend has a dream series 1 has dual on it, had the muffler shop do the cut out came out great!!
Old 17 Jan 2004, 01:54 am
So they used the trim pieces for the n/a PT?
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 17 Jan 2004, 02:09 am
Actually, the Dream 1 isn't a turbo so the cut out trim pieces would fit. How about those with turbos with duals?
Old 17 Jan 2004, 05:27 am
divots divots is offline
I just left mine "un-trimmed". BTW if you get the Mopar duals, don't use the supplied template for the cutout. Mine did not match the factory shape at all. Just make your own template using the driver's side cutout.
Aloha,
Mark
Old 17 Jan 2004, 03:03 pm
BL CRUZR BL CRUZR is offline
I bought my BTG duals in Oct '02 and I don't think anyone realized the trim pieces wouldn't fit a GT. They don't fit very well, but if you're really committed you can make them work anyway. It's hard to get the screws in (they have to go in crooked) but not impossible. I considered it worth the trouble.
John
2003 GT Silver, factory flames, pinstripes, BTG duals, stage 1, 3 silencers removed, K&N dropin, Suspension Techniques sways, BTG strut brace, 17X8 Sport Edition wheels, Yokohama 245-40 AVS ES100 tires, RED calipers, Hidden Hitch
Old 17 Jan 2004, 05:36 pm
Gear_Head Gear_Head is offline
The pass side facia cuts easily. I bought the cutout trims specifically because I had to cut the passenger side. There is an issue with the trims because the drivers side facia cutout is wider for the GT than the NA. If installed carefully they fit fine. I used small stainless bolts and nuts on the drivers side to attach the trim cutout. That gave me more room for adjustment and a tighter fit to the facia and it made no difference that the attaching bolts were crooked. You can't even tell. There is just 1 little spot on the right side of the cutout trimplate that shows. You have to look real close to see it. Here's a pic.....
Old 18 Jan 2004, 08:07 pm
mcruz mcruz is offline
I cut the facia with tin snips and didn't install cutout trim. I smoothed the cut with a file and sandpaper and you can't tell without getting on your hands and knees. If someone comes out with cutout trims that fit right I will get them.
Marty from MD
Black GT 03, BTG cat/back duals, rocket taillights, BTG shock strut bar, & Blane hood struts
vB code is On
Tailpipe cleaning PTucker The Detail Shop 2 01 Feb 2004 12:26 pm
3" exhaust turbo to tailpipe tthrift Turbo Performance 8 25 Aug 2003 01:01 pm
  Mortgages | Refinance | Personal Loan | Loans | Refinance
