has anyone tryed the CryO2 systems
  #11 (permalink)
Old 21 Jan 2004, 03:23 am
quote:Originally posted by Jason_L
quote:Originally posted by PVO PT
skeeter
you are correct on the boost cut at lower inlet temps. I know it sucks
I'd assume anyone running an IC sprayer would have invested in a boost controller. Bypass the the WGA solenoid, up your boost to take advantage of the cooler intake charge, and you're good to go
2003 Electric Blue GT
- Greddy E0-1, boost and AFR guages
- Custom exhaust: no muffler, side exit.
- Replaced air box with open end cone filter.
- Stage 1
  #12 (permalink)
Old 21 Jan 2004, 03:24 am
skeeter
- Stage 1
  #13 (permalink)
Old 22 Jan 2004, 04:31 pm
TripleJackInGA, "I'll hafta check whren I go get a smoke later.I *think* it's like 1024 or something." How long a smoke break do they take in Ga. these days??
  #14 (permalink)
Old 23 Jan 2004, 11:58 pm
Send a message via AIM to Rolo
LOL, Steel!
Triple's DC2 # is 1025.
I took my S/N badge off. It was crooked and drove me nuts. I asked the dealer to fix it, but they are incopetent and could not. The badge is just a piece of rubber with silver double-sided tape. The lettering is on the back side of the rubber. You can warm it up (just let it sit in the sun) and pull it off. If you separate the tape from the rubber, so slowly so you do not pull some of the ink off of the rubber. I need to get a replacement for the tape since the dealer wrinkled it in their futile and failed attempt to remove it.
I thought the computer compensated based on pressure, not temperature (MAP sensor)..?
Is there a link to this CryO2 ball thingie?
Flight Systems ? JohnM Stage Turbo Kits 1 06 Dec 2005 02:05 pm
Exhaust Systems for Automatic virtuadc Turbo Performance 20 23 Apr 2004 02:49 am
New PT Exhaust systems ptgtcb Turbo Performance 19 27 Mar 2004 12:31 am
Exhaust systems elmonkey Tech & Performance Forum 0 26 Mar 2003 02:27 pm
Exhaust Systems mich_13 Tech & Performance Forum 5 15 Feb 2002 09:53 pm
