has anyone tryed the CryO2 systems
Old 17 Jan 2004, 07:24 pm
Default has anyone tryed the CryO2 systems
I was wondering if anyone has tried the CryO2 system with there Turbo I have heard good things from a few people who use it on other types of Cars the idea behind the product seam sound and it had a atvantage since no gas in taken in to the Intake they can't void your warranty ... it uses a cooling ball in side the air tube just before the throttle body and the gas then is sprayed on the front side of the intercooler at about -200 .. so what you get from this system is colder and dencer air and this should make more HP
Old 17 Jan 2004, 07:47 pm
I thought about that, but the thing ain't cheap, that's for sure.I get about the same results at the track from a $1 bag of ice, although it's obviously not quite as convenient.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 18 Jan 2004, 04:39 am
the problem is that on the turbo pts the computer is what adjusts the boost . So in this case ,yes you are running dencer air which on most turbo cars would give you more hp but on ours the computer cuts back on the boost to compinsate and still gives you the same hp . now correct me if im wrong but this is the way I understand it .
2003 Dream cruiser 2 #1434
mopar bov and k&n drop in filter ,billet shorty antenna, silencers removed, custom painted rear shelf that says\"Dream Cruiser II\"and maybe, doubtfully soon------stage 1
Old 18 Jan 2004, 04:40 am
And if im wrong ...... "I'll bid $1.00, Bob" (the price is right)
Old 18 Jan 2004, 05:02 pm
Well, I wanted to test the 'bag-O-ice' theory on the dyno the other day, but they wouldn't allow me enough time to do it.At the track I typically let the bag of ice sit on the intake until it's completely melted and the intake is cold to the touch.I know this gives me at least a tenth in the 1/4, but I wanted to verify it.
www.cybermopar.com
TripleJack
Old 18 Jan 2004, 07:17 pm
hey triple
whats the series number for your dream mine is 1434
Old 19 Jan 2004, 04:54 am
skeeter
you are correct on the boost cut at lower inlet temps. I know it sucks
Old 19 Jan 2004, 10:37 am
I'll hafta check whren I go get a smoke later.I *think* it's like 1024 or something.Ya know what I was wondering is what does one do about the numbered badge on the dash if for some odd reason you should need to replace it? I'm gonna ask the dealer about that next time I am there.
www.cybermopar.com
TripleJack
Old 20 Jan 2004, 02:13 am
was wondering the samething today
Old 21 Jan 2004, 03:21 am
quote:Originally posted by PVO PT
skeeter
I'd assume anyone running an IC sprayer would have invested in a boost controller. Bypass the the WGA solenoid, up your boost to take advantage of the cooler intake charge, and you're good to go The PCM dumps fuel to lower those egt's - the cooler charge will take care of that, so now add more air (boost) to bring the AFR's back to the 12's
2003 Electric Blue GT
- Greddy E0-1, boost and AFR guages
- Custom exhaust: no muffler, side exit.
- Replaced air box with open end cone filter.
- Stage 1
Flight Systems ? JohnM Stage Turbo Kits 1 06 Dec 2005 02:05 pm
Exhaust Systems for Automatic virtuadc Turbo Performance 20 23 Apr 2004 02:49 am
New PT Exhaust systems ptgtcb Turbo Performance 19 27 Mar 2004 12:31 am
Exhaust systems elmonkey Tech & Performance Forum 0 26 Mar 2003 02:27 pm
Exhaust Systems mich_13 Tech & Performance Forum 5 15 Feb 2002 09:53 pm
