screaming demon
Old 18 Jan 2004, 04:34 am
Default screaming demon
Who has one of these coils? Are they worth it ? need input to make a decision
Old 18 Jan 2004, 07:43 am
LAF LAF is offline
I want one, and 8.5mm wires. Go ahead and get them and let us know. Sometimes ya just gotta be first.
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge.
Elbert Hubbard (1856 - 1915)
2003 Electric Blue GT-30,000 Miles on the clock
Stage 1, Greddy Profec II B. Turbo Chargers Wastegate set to 13#. Forge Motors BOV (Blue of course). Brand AMX Intake/AirCooler Pipes/K&N Cone with Snorkel to Fender well, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3” down pipe with high flow cat, BTG axle back exhaust, Rear Spoiler. Russel Brake Lines/Hawk Brake Pads/Power Slot Cyro Rotors on a four corners
Support Your Right to Arm Bears
Old 18 Jan 2004, 08:23 am
I am currently running the screamin demon coil and 10mm magnecor wires. IMHO they made an immediate increase in performance. I also went to the single platinum Champion plugs 1heat range colder than stock gapped @ .042 at tha same time......
Old 18 Jan 2004, 02:12 pm
hey gear head is the car home yet??
Old 18 Jan 2004, 04:06 pm
Bob, not yet the body shop and insurance adjuster had a meeting earlier this week, and I joined in. Seems like after they got the hood open, and investigated further they needed an intercooler, radiator, transmission cooler, and there was a hole in the power steering pump big enough for me to stick my hand into. Another $ 3,750 in insurance adjusted. All parts on order and they are awaiting arrival.....
Old 18 Jan 2004, 05:21 pm
Don't expect anything less than perfection! Do not accept the vehicle unless you are completly satisfied with the repairs, no bring it back and we will fix it B.S. Get them to raise the vehicle up and look at everything repaired and write down anything questionable. Only accept factory fit and finish or better. Every part, nut and bolt should have factory part number associated with it. Body shop mechanics, scary! Hope your on the road soon!
Old 18 Jan 2004, 11:37 pm
TThrift has the Scremin Demon coil, 8.5mm Magnecor and is using the Champion #3032 single Platinum plugs. I just received my Screamin Demon this week. I'll be installing it along with Magnecor 8.5mm, and Champion #3032 plugs. I'll you know the results.
<b><font color=\"red\">2003 LT ALMOND GT</b></font id=\"red\">
<font color=\"blue\">MODS:</font id=\"blue\">
Stage I, Custom Pin Stripe, Rear Spoiler, BTG Polished Strut Tower Brace, Borla 2.5\" CAT Back Dual Exhaust, and AirAid Intake System, Polished Front & Rear Sill Plates, Chrome Antenna Bezel w/10\" Chrome Billet Antenna, Mobil 1 and K&N Gold Filter, \"Flame\" 3rd Brake Light, \"Streamline Design\" PT Cruiser Visor, Rear Shelf Graphics and Dash Dots on Steering Wheel, and MGW \"GT\" Auto Shift Knob,Chrome Door Lock Pulls, Chrome Billet A/C Knobs with Acrylic Red Inserts, Chrome Oil Cap, Chrome Dip Stick, Chrome Radio Knob, Blane\'s Hood Lift Kit. Chrome Raidiator Coolant Bottle Cover, Timing Belt Housing Cover, Shock Tower Covers w/Nuts, Power Brake CYL Cap Cover, Windshield Washer Cap Cover, A/C Line Connector Cap Covers, A/C Check Valve Cap Covers and Radiator Cap Cover. \"GT2\" Rolo Red Calipers, Magnecor 8.5mm Spark Plug Wires - Red, Red Wire Looms, Billet Aluminum Steering Wheel Caps (4), Chrome Coin Tray Trim Cover, Chrome Shifter Bezel Tirm Ring, Yoko AVID V4S - 215/50/70\'s, TYC Euro Style Back-up Lights, and Screamin Demon Coil
Old 19 Jan 2004, 04:02 am
Is anyone having ignition troubles or hard starting with stock ignition set up?? I have a hot ignition set up in my 87 Mustang and it does not make more HP but makes car smoother and easy starting!!
Old 19 Jan 2004, 11:35 am
WHO did you get the coil and wires from ???
03 Steel Blue Pearl Turbo, Stage 1, Mopar BOV, Magnaflow performance muffler, My Air Box mod., AMXpipe W/K&N filter, LED lighting,PT Tunning rear lowering springs & BGT Strut tower brace, Hankooks Ventus tires, Rage Motif 17 in. wheels. Tribal pinstrips by Palmer (who else), Color match paint by Etouchup.com, Plugs and wires by Sparkplugs.com, http://members.cardomain.com/rodrungtpt
Screamin' Demon Coil, LiveWires & Champion HighFive Tech & Performance Forum 2 27 Mar 2007 08:57 am
Screamin' Demon Ignition Coil... Silvercruzr Tech & Performance Forum 7 15 Jun 2005 08:13 am
Screamin Demon Coil and Howell Automotive snakepitt1 Tech & Performance Forum 4 21 Jun 2004 11:44 pm
screaming demon coil plug gap GTCOOL Stage Turbo Kits 1 10 Jun 2004 07:15 pm
Screamin Demon vs MSD Coil Pack Turbo Red Turbo Performance 1 08 Jan 2004 07:26 pm
  Wordpress Theme | Debt Consolidation | Debt Consolidation | Debt Consolidation | Millsberry
