03 turbo calling all experts
Old 24 Jan 2012, 01:34 am
Unhappy 03 turbo calling all experts
Ok guys I am gonna be as simple and informative as possible need help. I bought my pt from single owner it has 130,000 miles I was told timing belt was done but alas it broke and against odds bent valves.
Replaced parts: timing belt, water pump, a used head with 50,000 miles on it, all new gaskets, oil pressure switch, pcv valve, spark plugs, plug wires, new coil (will explain why in a sec), all motor mounts on passenger side.
Ok So now hard part car is completely back together and I am now having the infamous ignition problem. DA DA DA sorry pulling hair out have to use humor. I have been reading these forums for a while and many say they have same problem and symptoms but no solutions.
CODES: p2305, p0351, p2302, p0300, p0352
I know what the codes mean and here is what the car is doing and what i have done.
Car will start and idle just fine then as i start down street engine light will come on and car will go limp. I turn car off check codes then reset and start car and it runs fine for about another block before happening again.
Thought it was coil bought a new one and had the same issue so i have checked coil, plugs, wires.
I wasn't sure if having a tooth out of time would cause this does anybody have any suggestions?
Old 24 Jan 2012, 08:10 am
Default Re: 03 turbo calling all experts
Have you checked the timing to make sure is not off?
Old 24 Jan 2012, 02:24 pm
I did have the timing off at first since the timing seems to be so hard to set on these 2.4l I am about 99% sure I have it right now. I checked it multipule times setting it back and forth a tooth and checking with a remote start then starting the car carefully. I read all the forums on it and settle on the spot where when you put a ruler across it the timing marks are a little above it and the crank is on the trailing edge of the tooth on the crank shaft. It matched every bit of information I could find on the subject. I also did a compression test. If u know of a way to make sure i Have set timing correct maybe picture or how to tell for 100% I would be glad to check again.
Old 24 Jan 2012, 05:59 pm
tryingbe's Avatar
http://www.tamparacing.com/forums/at...-picture-8.png
85 GLH
Watch out for anchor engine mounts!!
Tags
coil, ignition, spark plugs, timing belt, turbo
Any TIPM experts out there? Chromenut Tech & Performance Forum 3 26 Jun 2011 09:21 am
Need advice from the experts - time to give up on my PT? SHStormont General PT Cruiser Discussions 17 11 Jun 2011 02:07 pm
We are The Custom Wheel Experts! jas333 Vendors & Buyers Forum 3 10 Mar 2010 07:19 pm
A question for the paint experts on here CruisnHskrJim General PT Cruiser Discussions 4 15 Apr 2008 07:09 pm
Calling on all wheel experts!!! GstnNole Wheels, Tires, Suspension 8 07 Jun 2004 11:01 am
