Injector upgrade
Old 06 Feb 2012, 09:27 am
Kevhead's Avatar
Default Injector upgrade
I have an 04 GT with Stage 1 and an S2 Wastegate Accuator dialed in to 13-15 lb. of boost. At WOT I'm seeing Injector Duty cycles in the 85-90 range, and I'm thinking I am overworking the injectors. I was told I need to go with injectors one step larger to bring them in line and get a little more out of the boost I am running. I have the Getrag trans and it all runs well. I do seem to run out of power in the higher rpm's though. Any ideas on what injector size I should look at? Are the stock 04 turbo motor injectors considered already as "S1's"? I would like to swap them out and not get into other changes like a pump upgrade.
Old 06 Feb 2012, 07:36 pm
xwing777's Avatar
Default Re: Injector upgrade
No, you can run 18lbs with stock turbo fine. Plenty of us have been for years. 2004 allready have the larger injectors that have to be changed out on older models.
The important thing is to not run lean when you start bumping boost up and/or changing the tune. If you don't allready, get a wideband air/fuel guage so you can see how lean you are.
Injector advise Kevhead Tech & Performance Forum 0 03 Feb 2012 10:41 pm
Injector question OurPTGT Tech & Performance Forum 1 11 Dec 2011 08:10 pm
injector question? 03greygtcruiser Stage Turbo Kits 3 13 May 2008 09:46 pm
water injector 4SPEED Turbo Performance 2 16 Sep 2006 04:02 pm
Fuel Injector American flyer Tech & Performance Forum 7 14 Jan 2003 12:56 pm
