I'm Confused...........
Old 12 Feb 2012, 06:58 pm
PTconquest's Avatar
Default I'm Confused...........
So I spent the weekend installing all of the turbo piping for my Conquest, and with the help of a few friends, it didnt take to long. But it did get me wondering about something......how does a cold air intake on a turbo PT decrease performance....Now I talked to a few of my friends and all of them laughed.
Now before I go any further with the story, a little background on my friends and there experence with boost.....
2 Supercharged Mustangs
2 Big Turbo SRT-4
Twin Turbo Dodge Stealth R/T
240SX with an SR20DET swap
R-32 GTR Skyline
Now back to the story.......so from my understanding of turbo systems, air being pulled into the engine first gets compressed by the turbo.....now when air gets compressed it heats up, so it needs to be cooled before enter the engine, this is where the intercooler comes in...so now that the air is cooled down it the enters the engine.
So if the air is being cooled off before entering the engine the it shouldnt matter too much if the air filter pulls in a bit of hot air......hell there are guys who run the filter attached to the turbo, with no bad results.
If Im wrong about something, please let me know.
Old 12 Feb 2012, 07:07 pm
Default Re: I'm Confused...........
Your confused about where to post your question too. I moved you to the Turbo Performance part of the forum.
Old 12 Feb 2012, 08:10 pm
UptownSport's Avatar
Denser air contains more oxygen (and everything else) and is less susceptible
to detonation. Of course it matters- it'll be just that much hotter-
Old 12 Feb 2012, 09:36 pm
PTconquest's Avatar
Ok....but even if the air is warmer....its still a less restrictive intake....its allowing more air into the engine.....more air means more power.
Old 12 Feb 2012, 10:02 pm
You'll get plenty of cold air if you modify your OEM box and put a TTAB pipe, ...and will be a lot colder than a "CAI" or should a call it a "HAI"?
Old 12 Feb 2012, 10:44 pm
PTconquest's Avatar
To me that set up sounds like its more about making the stock intake system more responsive and less restrictive.....your still limited by the amount of air that can flow through the stock air box and filter.
Old 12 Feb 2012, 10:55 pm
No is not. There are people that did dyno tests on the PT GT and showed the most gain with a modified air box, K&N drop-in filter and TTAB pipe, because is the only real CAI. And some of these guys are making 300whp or more.
Old 13 Feb 2012, 05:30 pm
The intercooler does not return the air temp to the same temp as the intake air. Think in terms of a glass of water. If you apply heat to a glass of hot water it will rise to a higher temp than applying the same amount of heat to a glass of cold water. Conversely if you put ice cubes in a glass of hot water it won't get down to the same temp as putting ice cubes in a glass of cold water. You want to start with the lowest temp you can.
Old 13 Feb 2012, 06:20 pm
Some great answers here. For every 10* of added heat you lose one hp. Added heat will diminish your torque also. Big turbo guys have no choice but to go aftermarket as the stock intake will no longer fit. It will hurt the stock turbo more than a big turbo as the big turbo is pushing way more power. I'd go modified stock intake with the stock turbo.
Old 13 Feb 2012, 06:28 pm
Not at all a guy that should be giving turbo advice, do know guys use a huge injector and spray ethanol / water mix.
It does a really good job cooling the charge, and the added fuel allows more boost
confused 05PTGT General Turbo Discussions 1 28 Jan 2011 10:40 pm
OMG So Confused about 06 Key Fob flafishergal General PT Cruiser Discussions 4 21 Jan 2011 06:13 pm
New and confused mapowellsr General PT Cruiser Discussions 1 24 Mar 2010 07:20 pm
A bit confused????????? sgstudster1796 PT Cruiser Convertible Forum 12 15 Sep 2009 12:12 pm
Someone is a bit confused sakigt Wheels, Tires, Suspension 6 17 Dec 2003 03:02 pm
