any1 online to help?
Old 14 Feb 2012, 12:04 pm
Unhappy any1 online to help?
I bought a used 01' cruiser last nite and was awesome, smoothest clutch I have ever used, quiet, great. But this morning I went to go to work...and nothing... please help!!!
Old 14 Feb 2012, 12:50 pm
cruserdad1976's Avatar
Default Re: any1 online to help?
we will need a LOT mor info
1 will it not crank
2.will it just not start
3.will it not run
4.does the cluch not work
got to have more to go on to be of any help
Old 14 Feb 2012, 12:54 pm
..as cruserdad pointed out, you gave us almost nothing to go by in order for us to help out.
Would you go into a doctors office and say "it hurts, please help".
If you just bought it last night, why not call the seller and tell him it doesn't work, you want you money back. Apparently he fixed up just enough for you to get home.
Old 14 Feb 2012, 01:19 pm
ok Sorry, It turned over for 3 seconds and i could tell it was going to stall so i gave it gas, the rpm's were up but it still died. then tried again and nothing. jump charged the battery but still nothing.
Old 14 Feb 2012, 01:29 pm
I have tried to contact him, he lives about 2 hrs away, and I reeaally like this car. I just was not prepared to put it in the shop as soon as I bought it. I have been searching for a vehicle for 3 mths and finally found this one. FML!! And like I said it was perfect last night. It started fine 7-8 xs It was apparently an extra car for this family because there were 6 of them in the driveway., and I could tell it hadnt been moved because it was completely dry underneath and no tire marks in the 7 inches of snow, so he hadnt driven it. And I have never been apart of these online forums and wasn't sure if anyone would answer me so I was waiting for a response and thats pretty much why I didnt o into detail. I am ultimately taking it to the shop but can do some thimgs myself so Im praying for an easy fix.
Old 14 Feb 2012, 02:02 pm
GenniMae,
Sounds like the PT standing in one place and not being used affected something like the electrical system. Corrosion might have set in or something else that I can't think of at the moment. When you jump started it, did you give it a chance for the voltage/battery to charge up? Was it making good contact between the good battery and yours? It might have built up condensation in the fuel tank and you just got it home in time. Just thinking out loud. It's going to have to be looked over for fuel pressure and good spark by someone with the proper tools.
Old 14 Feb 2012, 02:39 pm
UptownSport's Avatar
So that we understand the problem-
It does crank, but won't start?
When you said RPM's went up, you meant it 'fired' a few times but not enough to run,
OR
It did run, but only for a moment
If it's a manual, tow it and let clutch out in 2d or 3d gear- See if it starts then.
When cars get old, they need work. If you are willing to do simple things,
like remove filter box and clean battery terminal, you can save a lot of
money and likely do a better job than paid help.
Sometimes boys are good to have around- They're happy to help women
on their cars. We're not much good for much anything else, tho.
Old 14 Feb 2012, 02:54 pm
Say What!
Old 24 Feb 2012, 11:43 pm
Dimitry's Avatar
Send a message via Skype™ to Dimitry
disconnect battery terminal clean them up with sand paper or if you have a special metal brush tool for battery terminal put them back and it should work if it is a electrical problem got the same thing with my wifys 02 every couple month no start corroded terminals
03 PT black 2.4 turbo manual. mine
02 PT silver 2.4 n/a manual. wify's
01 PT inferno red limited edition 2.4 n/a auto. mom's
Two new PT Forums are now online THISLPT Western PT Forum 6 18 Nov 2004 12:01 am
Finaly, My PT online! Ian-PT-GT General Turbo Discussions 14 23 Apr 2004 09:35 am
Zaino now available online skylight PT Cruiser News and Rumors 11 08 Sep 2003 09:16 am
