need advice
Old 25 Feb 2012, 08:41 am
dickie72's Avatar
Default need advice
I have 2006 gt I am wondering if a programmer or a chip is needed or just go with cold air and exhaust ? I want a little more power and sound but dont want to spend alot of money. Another question does the mopar blow off valve plate actually help remove un wanted heat or is just for the hissing sound? Any info greatly appreciated I am new to the turbo scene.
Old 25 Feb 2012, 03:00 pm
UptownSport's Avatar
Default Re: need advice
Bump.
Could someone help this man, don't know anything about turbo's here
Old 25 Feb 2012, 03:55 pm
It's the weekend. Maybe the Turbo guys are out out showin off to each other.
Old 25 Feb 2012, 04:34 pm
The only two thing that are available for the PT GT is a Stage 1 pcm and a Diablo Sport Predator programmer.(DSP). The Stage 1 is a plug and play, it will give you about 235hp ( about 220whp ) and better shifting if your is and automatic BUT they are discontinued so they are hard to find... Then you have the DSP, it'll give you a little more HP but you need to know what you doing and is recommended to get at least a wideband.
Don't get a "CAI" just do the air box mod and get a K&N filter..(I'll try to find a write up on how to do it )
Old 25 Feb 2012, 04:49 pm
dickie72's Avatar
thanks alot for the info I will look for info on the airbox mod too by the way your ride looks badass! One other quick question remove stock muffler and add a magnaflow or do the whole cat back magnaflow setup?
would like some advice lookingforhelp Tech & Performance Forum 9 07 Nov 2010 05:24 pm
A little advice! Musicman General Turbo Discussions 3 24 Jan 2008 06:49 am
need advice please tomcruz General PT Cruiser Discussions 5 17 Aug 2004 12:27 pm
Please help...I need some advice. Rainman General Turbo Discussions 14 10 Aug 2004 11:10 am
Need advice Pyropathic Exterior Accessories Forum 4 09 Aug 2004 06:47 pm
