engine code question
Old 28 Feb 2012, 07:56 am
Default engine code question
ok so i have this code
P0301 Cylinder 1 Misfire Detected
its a 03 pt gt turbo
i changed plugs, wires and coil pack but it still idles rough
any one know if it sould be the cam sensor or somthing else
03 gt atx mods are composite intake, big mouth bov lowered on drop zones with SRT-4 rims, full xenon urethane kit with 4" fog and 12000k hid, custome dual projectors, srt-4 front seats
Old 28 Feb 2012, 08:13 am
Default Re: engine code question
It wouldn't be the Cam or Crank sensor with that code. Could be a small vacuum leak. Look good all around number #3 cylinder. You can also read what others have done.
got a p0301 error code...help
engine light P0301
error code P0301
P0301 Code even with new plugs and wires?
Old 28 Feb 2012, 08:28 am
Also, just thought of this, you said you still have the code after changing plugs and wires; did you clear the old code after changing the ignition parts?
Old 28 Feb 2012, 08:38 am
Um no lol I'm a nEuB lol
But would that stop the chugging once that is done
Old 28 Feb 2012, 08:42 am
Well, to clear any old codes, you need to take off the negative battery cable for about 5 mintes, and step on the brake peddle to get rid of any residual charge. Then put it all back together. That along has solved some owners problems so it can't hurt.
P0303 engine code southerncruiser Tech & Performance Forum 6 19 Apr 2012 09:13 pm
Engine Code Help!! buckler General PT Cruiser Discussions 1 05 Dec 2011 09:19 pm
Engine Code 0340 PTTurbophile Tech & Performance Forum 9 12 Mar 2009 03:46 pm
How Serious: 0441 Engine Code?? BB General Turbo Discussions 5 29 May 2007 08:51 pm
0441 Engine Code BB General Turbo Discussions 0 21 May 2007 06:16 pm
