Spark Plugs
Old 09 Mar 2012, 09:42 am
PT_Panel's Avatar
Send a message via ICQ to PT_Panel
Default Spark Plugs
I have a couple of questions about plugs. I went to order some new plugs and they said they needed the VIN number? After I got the plugs which are NGK LZTR4AIX-11. I went on NGK website and they say I should use a 5 with a wider gap. When I called the store they said that the 4 is a hotter plug. Question is what makes a plug hotter or colder and what is the difference? Also if I use the 4 instead of the 5 will it hurt anything, How about gas milage etc. Thanks in advance.
06 PT LT Turbo, Back Doors welded in, Glass out, PTzed
Old 09 Mar 2012, 10:38 am
Default Re: Spark Plugs
A 5 with a wider gap would make it fire hotter but the gap widens out purity quick on these cars anyway Rather have the hotter plug. Burns fuel mixture better. Should give the better of the mileage the car will allow.
Old 09 Mar 2012, 12:28 pm
Those NGK LZTR4AIX-11 plugs are for the non turbo.So the part guy made a mistake. You should change them for the NGK LZTR5AIX-13 gapped at .040. ( btw, that's what I have in my car with no issues )
Spark plugs again fastfreddy1414 Turbo Performance 47 06 May 2010 08:58 am
7mm 8mm spark plugs help demon666 Tech & Performance Forum 2 07 Apr 2010 06:41 am
New Spark Plugs SteelBlueGT General Turbo Discussions 19 23 Oct 2004 04:52 pm
Spark Plugs kidturbofan Turbo Performance 2 08 Oct 2003 10:40 pm
spark plugs MNShaleCruiser Tech & Performance Forum 5 12 Dec 2001 03:17 am
