injector question
Old 14 Mar 2012, 06:41 am
Default injector question
ok so here is the deal,
2003 pt gt turbo atx shift tronic
Mechanic told me that my 1 injector is garbage,
so as i was posting up on another website for injectors someone said i
can use stg 1 injectors with out the stage 1 pcm,
could any one varify this
03 gt atx mods are composite intake, big mouth bov lowered on drop zones with SRT-4 rims, full xenon urethane kit with 4" fog and 12000k hid, custome dual projectors, srt-4 front seats
Old 14 Mar 2012, 07:52 am
Default Re: injector question
Are you using a DSP or Stage 1 pcm? if not, there is no need for Stage 1 injectors.
Otherwise you are just dumping fuel like crazy at WOT
Old 14 Mar 2012, 08:24 am
ROCKETMAN8060's Avatar
XtrmDC2 is right now if your planing to upgrade to Stage 1 or Diablo sport then you should go for it!!!
ROCKETMAN8060
Old 14 Mar 2012, 08:31 am
No I'm not using either
I made a post for stockers and everyone has the blue ones I need the purple ones and a comment was made that I did not need a PCM for the blue ones
Old 14 Mar 2012, 08:35 am
Yep, in closed-loop the PCM would use sensor readings to correct for the larger injectors, so no gain there by installing the larger injectors. On the other hand, at WOT the PCM goes into open-loop and goes with a specific preprogrammed set of parameters and since it can't tell that you have installed larger injectors, you will REALLY run rich. Our GT PTs already run rich at WOT to cool the combustion chambers as it is. The Stage 1 PCMs have an improved WOT program to make use of the larger injectors so the Stage 1 and larger injectors work hand-in-hand.
Jerry
Old 14 Mar 2012, 08:39 am
Jerry
I couldn't said it better my self! LOL!!! He is 100% right! You should consider getting a Stage 1 when ever you get the chance, you WILL love it!!!
ROCKETMAN8060
Old 14 Mar 2012, 08:44 am
Now I understand...let me tell you, I had an issue with my Stage 1 when I first got it and had to run the Stage 1 injectors (577cc) with the Stage 0 pcm and it ran fine until I went WOT and the gas mileage went down to about 12mpg.... so if is for an emergency, you can use them but stay away from WOT
Old 14 Mar 2012, 09:33 am
NEWB question here what is WOT lol
So I can run stg 1 injectors on a stg 0 pcm
Old 14 Mar 2012, 10:27 am
WOT - wide open throttle .
Yes, you can use them if you have no choice, until you get a DSP or Stage 1...but if you are not getting a DSP or Stage 1, what is the point of those bigger injectors?
Are you getting a Stage 1 or DSP ?
Old 14 Mar 2012, 11:17 am
Well now I'm looking for the PCM but can only find MTx and I need atx so next probably the diablo sport
What are the gains on DSP vs PCM
Injector advise Kevhead Tech & Performance Forum 0 03 Feb 2012 10:41 pm
Injector question OurPTGT Tech & Performance Forum 1 11 Dec 2011 08:10 pm
injector question? 03greygtcruiser Stage Turbo Kits 3 13 May 2008 09:46 pm
Injector Cleaning? BB Turbo Performance 7 14 Nov 2007 11:29 pm
Fuel Injector American flyer Tech & Performance Forum 7 14 Jan 2003 12:56 pm
