Stage 1 with Dual exhaust Problem
Old 29 Jan 2004, 04:37 pm
Default Stage 1 with Dual exhaust Problem
Had a Stage 1, performed perfect with stock exhaust. I put on a custom dual straight thru resonator--no muffler. Since I put on the new exhaust, car will not start as well, and performance is very sluggish. Seems to have extreme turbo lag. Anybody run into this problem??[:I][:I]
Old 29 Jan 2004, 05:09 pm
Have you tried running codes? Checked for vacuum leaks? Exhuast should not cause hard starting unless the system has some sort of obstruction (you didn't leave a shop rag in there did you?). You may loose just a little bottom end but you would not really notice it. It might show up on a dyno run as a loss of a little power down low but the Seat-of-the-pants dyno would not really feel it a bunch. I don't like to bog my engine down low anyhow.
Old 29 Jan 2004, 05:38 pm
Far out of my knowledge but from what I read maybe something like disconnecting the battery or maybe you have to go through all the learning steps for the tranny again?
Old 29 Jan 2004, 06:44 pm
did you bust an O2 sensor?
Old 29 Jan 2004, 07:06 pm
Send a message via AIM to ptcruzin42
my 02 sensor got messed up when my exhaust got installed, caused backfiring problems and lsuggish response, cracked a spark plug to, check that out.
Life dealt me a hand and I\'m bluffing hard, I\'m playing poker with a joker and some uno cards.
Old 29 Jan 2004, 10:17 pm
backfiring and sluggishness, hmmmmm... do you have an air-fuel or EGT gauge??? You may be runninig very rich,you may have blown out a plug.. try resetting your computer. If anything your car should spool faster than with the stock exhaust...
My Cruiser is slow. I love the law.
Mopar performance 2.5-inch dual exhaust system Gary04GT Turbo Performance 28 04 Nov 2006 01:31 pm
Dual exhaust Ed Lim Tech & Performance Forum 8 17 Aug 2005 11:29 pm
Dual Exhaust with Hitch crazie.eddie Tech & Performance Forum 7 10 Oct 2004 04:47 pm
2005 GT Convertible - Best Dual Exhaust??? MACE Turbo Performance 20 14 Aug 2004 12:12 am
Dual Exhaust Questions..... amazingarthur General Turbo Discussions 21 23 Jan 2004 11:18 pm
