wastegate
Old 06 Apr 2012, 08:54 pm
Default wastegate
I need someone to point me in the right direction to acquire the aftermarket waste gate to up the boost a little on my 08 lite that i have read about.
Old 07 Apr 2012, 09:34 am
ROCKETMAN8060's Avatar
Default Re: wastegate
People some times try to find stage 2 wategates from SRT4 and install Stage 1 with it! You be around 15+ psi of boost easy!
ROCKETMAN8060
Old 07 Apr 2012, 11:24 am
Maybe im just a little slow..lol. I was hoping that there were alot of aftermarket stuff/upgrades for these being that they have the same base power plant as the srt4. however the more i look the more im depressed..lol
Old 07 Apr 2012, 11:52 pm
Kawizx9r's Avatar
Well a better/after-market wastegate will surely be better but unless you're full bolt-on and tuned/tuning there's no need for another wga aside from the stock one.
The stock wastegate is fitted with a 10lb spring which allows you to boost and hold up to 20psi. Normally though, the first thing to go out is the diaphragm inside the wga which could lead to boost leaks.
If you insist on a different wga, my recommendations would be; Forward Motion wga or a Stage 2 wga (normally known as an srt-4 s2 wga). Don't get an AGP wga, they can cause some serious part-throttle boost.
Kawi is a friggin genius!
AGP wastegate help.... golf55555 Turbo Performance 0 28 Apr 2011 06:44 pm
What is a wastegate solenoid 1? chryslergirl Tech & Performance Forum 4 12 Nov 2010 05:07 am
Wastegate matt87951 Turbo Performance 8 04 Oct 2007 01:56 pm
AGP Wastegate strangelove Turbo Performance 8 21 Oct 2006 08:01 am
Wastegate? rice_killing_GT Turbo Performance 34 04 Mar 2004 04:00 pm
