Pass emissions test with no cat?
Old 09 Apr 2012, 09:29 pm
Talking Pass emissions test with no cat?
I'm thinking of getting a catless neeedswings down pipe and was wondering if I'd be able to pass emissions test without it. I heard the stage 1 I'm waiting for doesnt read the O2 sensor by the cat so the computer won't kno if u have one or not. Is this true? Will I pass emissions tests without a cat?
Purple 2005 PT GT ATX w/ Mopar stage 1 PCM, Diablosport 93 oct tune, airbox mod, K&N drop in filter, Mopar BOV, AGP wastegate (8 psi spring), Custom made stage 1 camshafts, motor mount inserts, NGK Iridium plugs, MSD wires, ARP Head Studs, Gates Racing Timing Belt, AC Delete kit, purple painted Valve cover, Rebuilt (stock) Turbo , AEM Boost, Oil Pressure, and Wideband guages, triple guage A pillar pod, Strut Tower brace, Needswings 3in o2 housing, 3in downpipe w/ high flow cat and electric cutout, 2.5in Magnaflow catback, custom check valve, custom larger capacity trans cooler w/ built in cooling fan, Eibachs pro lowering springs, KYP front and rear struts, matte black hood and grille, gloss black stock SRT neon rims, purple lug nuts, blacked out tailights and reflectors so far. Built and bored out motor, AGP S256 turbo, ported cylinder head, and built trans soon to come.
Old 09 Apr 2012, 09:49 pm
Default Re: Pass emissions test with no cat?
A lot of places have a visual inspection besides the sniff test. If they see the CAT is missing you failed. Better find out if that's the way they do it in your state.
Old 09 Apr 2012, 10:02 pm
Exclamation Re: Pass emissions test with no cat?
If worse comes to worst I'll just get a high flow cat. Cuz I'm looking on the neeedswings site and they don't seem to have downpipes with cats.
Old 09 Apr 2012, 10:47 pm
Kawizx9r's Avatar
I vaguely remember needswings having a high-flow cat option (think it was a Magnaflow) but I guess it's not available anymore.
As for passing without a cat, I wouldn't bother trying but if you insist, I suggest going to those places that let's you test and if you fail you pay nothing.
And yes, you're correct about Stage 1. It doesn't utilize the downstream o2 sensor however if you're on stock PCM and you remove your cat, you'll get a P0420 engine code and we all know engine codes = automatic fail.
Kawi is a friggin genius!
Old 10 Apr 2012, 10:52 am
Talking Re: Pass emissions test with no cat?
Thanks for the heads up I actually found the downpipe with cat on the needswings site. It was in the neon SRT 4 section.
cant pass emissions test buztanut General PT Cruiser Discussions 6 28 Dec 2010 10:30 am
Stage 1 Did not Pass California Smog Test nitrouspt Stage Turbo Kits 5 28 Oct 2009 09:16 pm
Stage 1 passed TX emissions test JohnM Stage Turbo Kits 6 11 Jul 2005 04:55 pm
Emissions Test With Stage One 2step Stage Turbo Kits 12 04 Jan 2005 01:40 am
