| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
For a cuple of days now every time I launch hard in 1st gear with or without traction control the Brake light on the dash lights up momentarily and sometimes even the bell rings.
What could be causing this? At first I thought that the traction control was causing it since it uses the brakes to limit wheelspin, but the I turned it off and it still happens. Any input? |
I'll check the fluid level, thanks.
Patriot Blue 5-Spd, Stage I, Mopar BOV, BTG Intake, Custom 3\" Turbo-Back, Spring Mod, BTG Shock Tower Brace, Vogtland Springs, Koni Shocks, Eibach Sway Bars, Azev Type M 18x8.5 wheels, Ventus K104 tires, Projector Bi-Xenon Lights, Rear spoiler, Autometer Gauges, Illuminated sill plates, K&N Oil Filter, Mopar subwoofer. Mexico City. See pics: http://www.sportcarsforum.com/forum/viewtopic.php?t=715 |
that's what it is. it won't look very low but i have seen it before. good job ptgtcb [^]
\'03 pt gt s1 mopar bov auto patriot blue 1925 modle t pulling truck w/864hp 673ft/lb 2002 harley, 1998 zrt 600 cat http://cpatrucks.org/members/endres.html |
I have that problem too but its only when Im at the track and e-braking [:I]
![]() 14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!! |
I always drive my car with the trac off and I have had the same occurence of the (parking) brake light under the tach coming on in 1st and 2nd gear, usually between 1000-3000 RPM. If its the brake fluid then its probably time for new brake pads instead of adding more fluid.
I posted about this same issue the other day, and got a great response from Cal Cruzer:
Your brakes are wearing and more fluid is now in the hydraulic system lowering the level in the reservoir.When you accelerate the fluid level drops enough to activate the sensor. Although the light comes on when you activate the emergency brake, it is also w low fluid light. You can add some more fluid to the reaservoir and it will stop or you can do brakes and it will stop. Your brakes probably have more wear remaining on them but if you add fluid be sure to take it back out before you compress the caliper pistons (or brake cylinder pistons depending on your model) when you do brakes or it will back up out of the top of the reservoir and make a mess. good luck
2003 Electric Blue GT ![]() The Philadelphia Flyer |
| The Trunk Problem Thing | Bijou | General PT Cruiser Discussions | 23 | 07 Sep 2007 10:54 pm |
| What's this thing for? | scrisp2 | General PT Cruiser Discussions | 5 | 30 Oct 2005 04:35 pm |
| Shore Thing 4 Registrations | MYREDPT | Northeast PT Forum | 0 | 02 Sep 2004 08:14 am |
| any nods for this ugly plastic thing? | Punch | Exterior & Interior Styling | 4 | 02 Nov 2003 08:45 pm |
| Current Shore Thing Counts | DEF | Northeast PT Forum | 0 | 25 Aug 2003 04:16 pm |
