Speed limiter - can't remove using Predator
Like Tree5Likes
Old 16 May 2012, 04:20 am
Huunterhood's Avatar
Default Speed limiter - can't remove using Predator
Hi,
i'm driving a 03' GT HO, 5-speed using a custom (Predator) tune. Only other modifications i did was a K&N Typhoon Kit. Rev limiter is set to 6500 and is working.
My problem is: the speed limiter is still active. It stops the GT softly at about 118 mph, although the speed limiter is set to 190 mph. Mike from Diablosport is a bit clueless.
Anybody had a similar problem?
Old 16 May 2012, 05:09 am
Kawizx9r's Avatar
Default Re: Speed limiter - can't remove using Predator
I'd say, whoever gave you that tune messed up on that specific parameter.
Try the canned 93OCT tune that's pre-loaded on the Diablosport, and test it.
I really hope you're not just going around speeding everywhere though. With your simple bolt-on, I assume you are since you wouldn't trap anwhere close to 105mph
PS If you said custom as in the 93OCT tune itself, just say canned or 93OCT tune. And again, if it is the canned tune I'd try loading the STOCK tune and reloading the canned tune again. Also make sure your hand-held is up to date.
Kawi is a friggin genius!
Old 16 May 2012, 07:08 am
Originally Posted by Huunterhood View Post
Hi,
My problem is: the speed limiter is still active. It stops the cars softly at about 118 mph, although it is set to 190 mph. The guyz over at DiabloSport are clueless.
WOW, I guess you want to do 200mph? LOL
Old 16 May 2012, 07:12 am
Kawizx9r's Avatar
Know what Xtrm, I'll tell myself that he meant KPH
NicksCruiser likes this.
Old 16 May 2012, 12:09 pm
Soon as I update my DSP I'll do a highway pull. I've been to 123 in it, on an abandoned airstrip, but almost crashed trying to stop before ending up in the trees at the end...lol...
Pipeous likes this.
Old 22 May 2012, 04:41 am
No, the parameters are ok, double-checked by Mike from diablosport. The tune installed is made especially for my GT. Had no luck with the 93OCT or stock-tune either. I meant 190mph, as this is the max value in the speed limiter. Of course it is not able to reach 200 mph. But with my setup, it should do more than 125 mph. The Predator 7134 is up to date and I'm driving a European GT using a 2,5" catback, NGK-sparks & Magnecore race wires & optimized intake.
If i like to drive 200 mph, I would use a Hayabuza, not a PT with crappy brakes ...
ROCKETMAN8060 likes this.
Old 22 May 2012, 01:04 pm
UptownSport's Avatar
yikes.
Old 22 May 2012, 02:42 pm
Hopefully you are doing this way out in the boonies where NOBODY else is around. If not here's hoping you get caught. Then you will find out it really isn't worth it. My buddy got caught doing 130 mph and by the time he paid the lawyer and court fines he had to sell his car to pay for it all. Now he drives a slow Honda. Too funny. Flame suit on for idiots wanting to flame.
Old 22 May 2012, 03:02 pm
ROCKETMAN8060's Avatar
Keep me posted if you got this fix! I will be getting a Tuner soon and one of the things I want to do is kill that speed limiter!
ROCKETMAN8060
Old 22 May 2012, 03:31 pm
^ are you trying to make "pure de PT" ? ( Mashed PT ) ...
Tags
predator speed limiter
HELP WITH COURT & SPEED LIMITER! NICOLE-SMITH Tech & Performance Forum 21 29 Jun 2008 10:33 am
what is the speed limiter for a NA PT? Ctown General PT Cruiser Discussions 44 06 Nov 2006 02:22 am
Speed Limiter on Turbo Lite ghensley_98 Stage Turbo Kits 4 24 Jun 2004 07:59 pm
Can we disable the speed limiter? MEXICANPT Turbo Performance 9 15 Dec 2003 07:37 pm
Stage I speed limiter MEXICANPT Stage Turbo Kits 1 20 Aug 2003 12:29 am
