It is here, Now it's time, Wideband Install
Old 25 May 2012, 09:03 am
Exclamation It is here, Now it's time, Wideband Install
11111111
Not sure really
Old 25 May 2012, 09:31 am
ROCKETMAN8060's Avatar
Default Re: It is here, Now it's time, Wideband Install
By the firewall there is sometimes holes cover with a plastic black cap thats what I ran most of my cables go see if you have any of those if not then you can drill but make sure to cover them with some tipe of plastic cap so fumes and other stuff wont get inside! Take pictures! Looking good!
ROCKETMAN8060
Old 26 May 2012, 06:27 am
Kawizx9r's Avatar
More specifically a "grommet" which will seal the surround area of your cable.
I would run it where you ran your vacuum line for your boost/vac gauge. That's how I did mine.
Kawi is a friggin genius!
Old 26 May 2012, 07:30 am
Question Re: It is here, Now it's time, Wideband Install
I have never ran any lines for anything
Old 26 May 2012, 09:34 pm
I cut the rubber grommet where the hood pull cable goes through the firewall and all my runs fit through there. I left the grommet around the hole to keep the wires safe, but I use black silicone to seal it up when done. This way if I have to run other, I just take a knife out and carefully clean out the silicone, then run the new wires and seal it back up again. Works great.
Wideband Install LooseJox Turbo Performance 1 19 May 2012 02:23 pm
Wideband/Boost Gauges Again Busa_Powered General Turbo Discussions 5 21 Mar 2012 05:32 pm
Stock Turbo, wideband, and leak tester Kawizx9r Classifieds: For Sale/Trade 1 13 Jun 2011 01:23 pm
WTB Wideband vr_junkie Classifieds: Want To Buy 0 30 Mar 2010 03:47 pm
