Intake Mani Swap
Like Tree2Likes
  • 1 Post By UptownSport
  • 1 Post By Jimmy2011
Old 25 May 2012, 12:00 pm
Question Intake Mani Swap
I have a friend with a first gen neon swapped with srt4 motor and he was telling me about swapping out my intake mani with an srt4 or 2.0 neon DOHC intake mani.
I've read that the srt4 swap involves custom fab making it not worth the hassle.
But who here knows about the 2.0 swap? He tells me that a few PT guys over at neons.org have done it, but I was wondering if anyone here has done it. I have googled it and has gone to PTCrew and used their search, but it didn't work out to well.
I'm going to assume it will make a difference considering people have done it.
Also, where can I find some slimmer aftermarket fans for the PT?
Thanks,
-Jimmy
Wife's White 2002 Limited: Konig 17" Rims, 5000k White HID Head Lights,
My Red 2003 GT: Sold.....
Old 25 May 2012, 12:34 pm
Default Re: Intake Mani Swap
Jimmy, can't answer your questions but you'd be a heck a lot better off going for the PT Composite intake off the newer PT Turbo's. I take it you have the metal one. The composite takes very little work to make it fit, adds about 10hp (what I'm told) and you don't have to buy another slimmer fan. The SRT intake can't add that much more than the new composite intake but it's a heck of a lot more trouble to add to the PT.
Old 25 May 2012, 12:35 pm
You'll have a hard time finding aftermarket fans for an 03 GT, since we have those expensive radiator fans only found in that year GT.
Old 25 May 2012, 12:57 pm
Smile Re: Intake Mani Swap
I plan on doing the Plastic Swap, but I wanted to see what people thought about the 2.0 swap. Also, I was asking about a replacement slim radiator fan because ours are heavy from what I hear.
Thanks you guys!
Old 25 May 2012, 12:58 pm
UptownSport's Avatar
You could try 'pusher' fans if there's enough room.
My buddy found the smallest one he could find for his Neon and says it works ...
(Neon isn't a PT, Neon isn't a PT, Neon isn't a PT)
There's; The Jeep Liberty manifold, 'o1 up Stratus, original and 'Low Rumble' old 2.4, a really junk aftermarket, the Cvan, the turbo manifold and-
As for the DOHC Manifold, it has very short runners.
(Without integrated water neck)
The (DOHC) 2.0 will produce useable power up to ~7500 RPM Stock (kinda) and on a perfect day you might shift at 7800
- Unless you have very long duration cams a 2.4 just isn't going to do that, and needs longer runners.
Here's a 'stock' one:
'01 and up head used a different intake manifold bolt pattern, but that hasn't really stopped anyone.
Over the years we've tried dozens of different configurations;
THis was on our 2.2:
Jimmy2011 likes this.
Old 25 May 2012, 01:49 pm
Talking Re: Intake Mani Swap
Ya after seeing that mess I am sure I'll stick with the composite haha thanks uptown
XtrmDC2 likes this.
Old 25 May 2012, 03:23 pm
Oh, and it was a turbo- Sorry- turbo heads don't seem too concerned with runner length
Old 26 May 2012, 10:38 am
Question Re: Intake Mani Swap
Since this is solved I have a quick question. A friend told me to look into a stage 1 and a dsp since I am 5speed would that be necessary? Or what? Thanks guys.
Old 26 May 2012, 10:47 am
Don't have the Turbo from what I know they don't make the Stage 1 anymore so it's hit and miss if you can find one. What I do know, it that because you have the 5-speed, the Diablo Predator (might be spelled wrong) is the perfect upgrade for performance for your car. Hopefully someone will come along with more information on it for you.
Old 26 May 2012, 11:58 am
Yeah, from what I understood was the if you are auto a stage 1 is a must, but 5-speed DiabloSport Predator is the way to go.
Just didn't know if I should get both or not. I see that Gus has/will have both.
Thanks for all your help Crewzin!
-Jimmy
SDK Exhaust Mani Upgrades Jimmy2011 Turbo Performance 7 03 May 2012 12:18 am
turbo intake mani on NA bhunt41 Tech & Performance Forum 25 18 Jul 2011 08:06 pm
wtb 05-up upper intake manifold, throttle body, intake hose to turbo,aircleanor lid 1autodr Classifieds: Want To Buy 1 24 Feb 2011 05:15 pm
FS, Complete HEAD, Throttle body, Valve Cover, PT TURBO Intake Mani, Coil pack.... Floner Classifieds: For Sale/Trade 2 20 May 2009 10:19 am
FS: intake mani, coilpack, TB argentower Classifieds: For Sale/Trade 2 24 Dec 2005 07:17 pm
