Dyno Results for Hahn Turbo PT!!
Old 06 Feb 2004, 10:02 pm
Ant Ant is offline
Default Dyno Results for Hahn Turbo PT!!
After driving the car for 1 year with the turbo setup I finally made it to the dyno today.
Little history:
Within the past few weeks I put in a Wideband O2 sensor for constant monitoring during boost, GT intake, bored TB, and 30 lb injectors.
With static FP set to ~25 it idled a little rough but that is the # that seemed to work best.
My goal for going to the dyno was to:
1. get the AFR curve in a good/safe range
2. see if we can dial out some of the overlap and get it to idle better.
Both were accomplished!
OK now the results:
17 PULLS!! yes that is correct 17!
9-10psi
2nd pull had me very safe on the AFR (very rich)
184.39 HP 152.85 TQ
Once we got the AFR on (~12:1) we were closer to 200 HP
Next was adjusting the cam gears. Nick Riley from NRGY HEADS did those adjustment, he has done this MANY times so I was able to learn from him. I was in charge of the Fuel.
Run 11
229.29 HP 258.40 TQ
We tryed turning the boost up to ~11-12 and experience some break up. Ended up pulling close to 240 HP but it was unsafe at those levels so turned it back down.
Car idles nicely now with the 30lber's. I think they are capable of handling close to 300 HP.
I have the Crane ignition w/timing retard which needs to be installed next. Then I can get that boost up to 12-14 and put some real #'s down.
The #'s I posted were peak. The goal is to make more power accross the board and not shoot for seeing the highest #'s.
I would say for the relatively low boost levels I was running, the power is very respectable. There is certainly a LOT more in this minivan!
BTW the little method I used for adjusting FP,( I shared with Bob and OC Cruzer, AL) at higher boost levels worked flawlessy. When I learn how to post the charts you will see that AFR went almost immediately to 12:1 and stayed very steady throughout the run. This was from ~40mph-112mph at ~55psi WOT.
Old 06 Feb 2004, 11:54 pm
Send a message via AIM to macster
Sweet good info. If you need help posting the info let me know.
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
Old 07 Feb 2004, 06:52 am
Nice numbers Ant! Are you going to take it to the track and give us some 1/4 mile times anytime soon?[8)]
Deen
Old 07 Feb 2004, 07:27 am
Great Ant ... I know it's been long time coming and you've been very patient . Phatdad will be happy to see these ,also . Jeff
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
Old 07 Feb 2004, 12:48 pm
Ant Ant is offline
I plan on getting to the track fairly soon. They do Fri. & Sat night races every week, but I work those nights. I will have to take a night off to play. It is perfect track weather here in AZ now.
I have not raced at a track for about 13 or 14 years so I will be plenty rusty. Should be interesting though![8)]
PT powered PT with:
Fully built HRC Turboed 2.4: Wiseco pistons, T2 rods, Port & Polished head (Bob Special) with oversize Stainless Steel valves, #14 Crane Cams, AF/X UDP, No balance shafts, Custom 3\" downpipe, 3\" hi flow exhaust, Ported GT intake manifold, Bored Throttle Body, 30 lb injectors, Water/Alc. injection
Old 07 Feb 2004, 06:23 pm
Nice results, Bro! hmmm..........perhaps I *can* get another Series 1 down the road and pump her up a bit.I really liked the Metallic Urine 'Golden Nugget of Happiness'.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 08 Feb 2004, 05:07 pm
Send a message via AIM to 03baggedturbo
Thats great. I didnt know we had cam gears that were that adjustable. Most stock cam gears are just bolted on.. you can pull skip one tooth but thats a lot.. how did you do it? Also where did you get your TB bored out? Do you think it helped you?
Thanks for the info those are some impresive #'s ADAM
Old 09 Feb 2004, 08:27 am
Crane has had adjustable cam gears for a couple of years and I believe Ant had his throttle body bored by Bob Stockum as have a few others with n/a cruisers . The adjustable cam gears work by having slots cut into mounting holes . The drawback is to effectively use them a "dyno" provides the truest info. These gears allow precise timing for both your intake cam and exhaust cam . This isn't to say they can't be adjusted without a dyno as they have degree scales on the gears but unless the cam mfg or another rodder provides the specs then one can't effectively use them . Another drawback is that you can't use your upper timing cover ,however I think one could fab one out of sheetmetal/plexiglass with a little work.
How lucky was I? (BOV install) alceryes General Turbo Discussions 27 18 Jul 2004 11:29 am
Turbo leaking oil 03baggedturbo Turbo Performance 5 09 Dec 2003 09:54 pm
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
dyno results kruzzinpt Turbo Performance 2 28 Jun 2003 09:52 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
  Web Advertising | Debt Consolidation | Wordpress Themes | Wordpress Theme | Debt Consolidation
