Couple weeks ago I put in the cat back Magnaflow system. A few issues I had with the install: both clamps looked nice and beefy but snapped when I tightened them. The slot for the factory stud was on the wrong side so I had to cut one on the opposite side. When I contacted Magnaflow about these issues their reply was 1) that happens, 2) the system wasn't designed for the turbo - they are still working on a turbo GT design. Also there's no place to mount the ground wire. I clamped mine to the hanger stud.
The whole set up was a little saggy so I took it to a muffler shop where they welded the joints. I noticed a problem right away but didn't have time to get back to the shop until today - the turn over the real axle puts it too close to the axle and it hits on bumps - really badly if you have rear passengers. The muffler shop thought the bend wasn't adequate for clearance and thought maybe it was a defective part. Being stainless he can't simply re-bend it. Waiting to hear back from Magnaflow on this. I do have Eibach springs, so this may compound the clearance problem. Performance wise - it's a bit louder than I originally wanted but not objectionable. The massive 4" tip looks gnarly and probably gave me a few h.p. Bottom line=If you're looking into a Magnaflow, I'd wait for a Turbo specific model - and buy some decent clamps. |
I don't think you should have welded the joints. Now adjustment is out of the question without a torch. It took me a couple of weekends to get my Borla setup adjusted right. Trial and error. There was more adjustment in the system than I orignaly thought. I just jammed all the pipes together as far as they would go, but that was not right. You really have to set it up.
The slot being in the wrong place is inexcusable. From what I understand, the exhaust systems for the NA and Turbo and interchangable so their excuse does not hold up.
I used a Magnaflow transverse and removed my spare from under the car. Plenty of clearance and the muffler is now out of view. If you don't mind doing that it is an option. I had a boot made for my spare which is in the back. The rear shelf can be lowered to the lowest bracket still.
When I had my bassani (and even my Borla onmy 01) that piece that goes around the rear axle would slam into either the axle, frame or the left arm of the Watts linkage. I had to have that piece cut and a replacement that was steeper placed. It helped on my 01, but with my turbo I had a custom system done and it is solid as a rock.
![]() 2003 GT Inferno Red,5-spd,Eibach Springs,Koni Sport Adjustables, Eibach front and rear Sway Bars, Mopar Stage 1,Mopar BOV,Custom 2.5\" Dual Tip Exhaust (Magnaflow),Hurst Short Throw Shifter, Pioneer DEH6500 Headunit, RF Punch 300 and 301 Amps,RF 12\" Sub and MB Quart Reference and Premium Speakers,Ronal RT 17x7.5\'s with Michelin Pilot Sport 225/45ZR17s, Koni Adjustible shocks, Keystone single scoop, GT Airraid Intake, Mopar Ground Effects Homepage: http://www.cardomain.com/id/ptgtredman http://blueman.ptenthusiasts.net/index.html |
Finally got to the muffler shop today. They cut out the section over the rear axle and rotated the piece to give me more clearance. The first guy who welded it up could have done a better job but I think it ended up more rotated than the original set up could have been (does that make sense?). So now with the Eibachs installed I have maybe 3 inches between the pipe and the axle. The banging is gone, but I haven't driven with back passengers yet. Firmer shocks would help.Yet another reason to buy the Koni's I've been lusting for....all I need is the $$$$$!!!!
[8)]
tezz Black 03 PT/GT - Autostick,Stage 1, Mopar BOV, DC rear sway, K&N filter/white baffle out, Magnaflow cat back, Eibach springs, billet strut bar, AMX CAI,3bagged UCP, Euro tail lenses, Revell shifter, misc. do-dads |
Should have gotten BTG, mine fit like a glove, didn't have to change a thing.
Marty from MD Black GT 03, BTG cat/back duals, rocket taillights, BTG shock strut bar, & Blane hood struts
| Flowmaster or Magnaflow | Tom and Marj Green | Turbo Performance | 17 | 30 Sep 2010 04:05 pm |
| MagnaFlow Exhaust System Installed | Stephen R. | Tech & Performance Forum | 15 | 30 Jul 2004 08:57 am |
| Any pics of the clearance with the Eibach kit? | alceryes | General PT Cruiser Discussions | 0 | 21 May 2004 02:09 pm |
| Magnaflow Question | PTGT Redman | Turbo Performance | 1 | 04 Jun 2003 11:29 pm |
| Suspension Issues | seanyboy | Tech & Performance Forum | 3 | 14 Jan 2002 02:08 am |
