New guy in need of UCP recommendations
Like Tree3Likes
  • 1 Post By OurPTGT
  • 1 Post By Busa_Powered
  • 1 Post By Busted_PT
Old 05 Sep 2012, 06:30 am
vessamj's Avatar
Default New guy in need of UCP recommendations
Hello everyone. I'm new in the game; recently put a Spectre intake filter on the stock intake pipe and performance torque mounts but otherwise bone-stock. Next I am looking to completely replace the stock UCP from intake to throttle body with BOV. However I have no clue what the best option is. Can anyone offer any advice? Thanks in advance!
Old 05 Sep 2012, 06:37 am
Default Re: New guy in need of UCP recommendations
first off, ditch that stock air filter to turbo pipe for a non restrictive one. It's also been proven the stock air box with K&N drop in filter works the best. Unless you just like the open filter for noise
If you're interested, there's a used but in very nice condition IC to TB pipe (UPP) f/s on PTCrewdotcom
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 05 Sep 2012, 06:49 am
vessamj's Avatar
Thanks for the info. Yea I like the noise and the look of the new filter better, tho I DONT like fake sounds (noisy mufflers, turbo sound tips, etc..). I would def be interested in the f/s part. Could I ask you to shoot me the link? My only source of internet is my tiny android phone and its a PITA sometimes... thanks again!
Old 05 Sep 2012, 07:01 am
check your PMs
Old 05 Sep 2012, 07:03 am
we don't need no stinking mufflers
wwpptc likes this.
Old 05 Sep 2012, 09:39 am
Kawizx9r's Avatar
+1!
Kawi is a friggin genius!
Old 07 Sep 2012, 02:25 pm
Exclamation Re: New guy in need of UCP recommendations
Do you have a link to this proof?
I would like to take a look at it, see when the differences show up.
Thanks!
vessamj likes this.
Old 07 Sep 2012, 02:58 pm
There is some old posts on here, don't remember were. They talked about dyno testing that showed this. Been a long time since I read it. But the fact that it gets it's air outside of the engine bay was the biggest reason for the performance advantage. Cooler air.
wwpptc likes this.
Old 07 Sep 2012, 03:21 pm
Pretty sure I read it over at PT Crew before I became a moderator here so it's been a long time. PT Crew guys are into every bit of power they can get and dyno tested everything including taking the rubber strip off the the outer rim of the engine bay. They do dyno runs and heat sensor readings on almost everything.
Old 07 Sep 2012, 07:37 pm
Thanks!
as stated before, THier at PTCrew dot com (search) did the DYNO test with stock air box vs, open cone filter. Stock box w/KN filter with a car or two cool down in between. I dont recall if the air box was modded or not. Mustang dyno BTW. I was there and set up the dyno time in
Tags
charge, intake, piping, ucp, upper
Need recommendations LindsPT Tech & Performance Forum 10 18 May 2011 04:32 pm
Upgrade Recommendations fabreezai Tech & Performance Forum 22 28 Apr 2011 07:17 pm
Recommendations Pat1USMC Wheels, Tires, Suspension 4 20 Jan 2010 02:59 am
Recommendations for a PT toolkit thender Tech & Performance Forum 5 16 Nov 2009 09:31 am
Flame Recommendations? madcruiser Exterior & Interior Styling 15 15 Aug 2003 01:01 am
