P0033 Error Code
Old 14 Sep 2012, 08:13 pm
TurboDucky's Avatar
Default P0033 Error Code
Finally got the Vert back together and running. I have a P0033 Error code and doesn't seem to be boosting. I know that that the code is the Turbo charger bypass valve circuit. But was wondering if someone could help narrow that down a bit?
All Vacuum lines and wires are connected and look good. Can't hear any vacuum leaks, etc. Could it be a bad solenoid? If so, which one?
I did a bunch of googling, but no real answers out there...
Thanks in advance.
-Gary-
2005 Dark Slate Gray Convertible - 2.4 Turbo Lite'ish - Automatic.
2001 PT Cruiser - NA - 5 Speed - Exhaust and CAI Mods - It's alive!!!
Old 10 Oct 2012, 02:35 pm
chris15's Avatar
Default Re: P0033 Error Code
Not sure if you're still using the stock surge valve or if you're using an aftermarket BOV. Quoted from SRTForums, so take this with a grain of salt:
P0033-SURGE VALVE SOLENOID CIRCUIT
When Monitored and Set Condition:
When Monitored: Ignition on or engine running. Battery voltage greater than 10 volts. Set Condition: The PCM will set the DTC if the actual state of the solenoid does not match the intended state.
Unhook a lead from the battery, unhook the connector to Blue #3 solenoid, replug connector, replug battery then test.
If the CEL comes back, check the wiring harness to Blue #3 solenoid then check the service manual for the pin outs and apply 12v to the solenoid to see if it actuates. If it doesn't...unplug the solenoid, do the delete mod on it by adding a resistor then hook your aftermarket BOV directly up to the TB (if you haven't already).
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 10 Oct 2012, 08:03 pm
TurboDucky's Avatar
Thanks for the info. It's still all stock for now.
I did swap out the Solenoids - same error. So I guess I need to do some of that Technician stuff. :-) I'm thinking it's a wiring issue, because it throws the CEL pretty much immediately after resetting the computer.
Old 11 Oct 2012, 11:40 am
chris15's Avatar
Electrical problems are some of the most difficult to dianose. I don't envy you at all, sad to say. :P
What does the error code PO 138 really mean? TheFox General Turbo Discussions 8 15 Jul 2012 10:10 pm
Can't get error code hidinginparadise Tech & Performance Forum 5 22 Jan 2012 04:45 pm
is it an error Code or something else saraPT04 Tech & Performance Forum 5 08 Oct 2010 02:46 pm
ERROR CODE PLEASE HELP Andrew514 General Turbo Discussions 2 27 Jun 2009 10:52 pm
CPS Error Code smokeydan1 Tech & Performance Forum 16 23 Sep 2008 09:58 pm
