turbo gauge installation
Old 16 Sep 2012, 07:53 pm
ajt ajt is offline
Default turbo gauge installation
hey just wondering how hard it is to install a boost guage and a fuel air ratio guage and what other guage is the eastist to install seeing as you can only get a 3 pod gauge pack for the pt? thanks
Old 16 Sep 2012, 08:16 pm
Default Re: turbo gauge installation
Well by your first two choices a pyrometer seems to be a logical fit?
Old 27 Sep 2012, 03:07 pm
BobHeine's Avatar
If you haven't already bought a 3-gauge, GlowShift sells a 2-gauge pillar pod for the PT Cruiser:
01-05 Chrysler PT Cruiser Full Size Dual Pillar Pod
2004 Silver Touring Turbo, Auto, STAGE 1, Mopar BOV, Plastic Intake, Custom Airbox-to-turbo pipe, Intercooler to Throttle Body Pipe, Borla Mopar dual exhaust, Eibach Springs, Sherwood dash kit. E&G Billet Aluminum Grill, APC Rolled Rear Pan. Next: Pillar pod with Auto Meter Boost and Wideband AFR gauges and custom downpipe
Old 27 Sep 2012, 04:19 pm
ATX or MTX?
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 28 Sep 2012, 12:37 am
Kawizx9r's Avatar
2 gauge pods are available, look harder.
Installing gauges/necessary wiring is easy, just follow the supplied instructions. I did a how-to on a boost gauge that would come up when one uses the search function; follow the procedure except skip the part where I mounted it on the steering column. Wideband requires you to drill a hole and weld a bung into your downpipe so you can insert the wideband sensor. If for some odd reason you can't get someone to weld it for you (any shop can do it for like 10-20 bucks including the bung), then you can go with a clamp-on solution that requires you to simply drill a hole in your downpipe.
Again, search is your friend.
Kawi is a friggin genius!
Old 29 Sep 2012, 08:02 pm
BobHeine's Avatar
I did a quick search on "boost gauge install" (which should include "installation"). Got 499 hits. First ten were useless so I tried advanced search, narrowing my search to just posts made by "Kawizx9r" with "boost gauge install" and I get 140 hits. The last (25th) one on the first page was titled "Turbo HO upgrades" and has a picture of the boost gauge on your steering column. I assume further reading through the other 115 posts will lead me to a more detailed description.
You have provided a lot of valuable advice on this site but if you believe it is easy to find using search, you may be mistaken. Nearly 10% of your ~1,500 posts include "boost gauge install" but none of them have that title.
I found the post you refer to in "Re: Steering Column Boost Gauge (MOCK)" and since it has a permalink, this may be just what the OP was looking for:
Apologies if I come across as a dick. I messed up my eye a few weeks ago and am unable to actually work on the car. Therefore I waste my time here.
Old 30 Sep 2012, 10:40 pm
Kawizx9r's Avatar
Thanks for linking that Bob; I had created a write-up as well as posting a full how-to on several other threads in the past.
Anyway I'm tired but to the OP, if you have anymore questions or need some more help just toss me a PM.
gauge pillar pod installation intim3 Interior Accessories Forum 4 16 Jun 2008 11:48 pm
Hahn turbo installation manual? vk Tech & Performance Forum 0 05 Feb 2005 11:22 pm
Installation Details for " Turbo Stuff " Gear_Head Turbo Performance 3 29 Apr 2003 11:00 am
Oil Gauge Installation Inferno Cruiser Tech & Performance Forum 4 25 Feb 2002 08:58 pm
Flame Gauge Kit Installation Guide PT Do It Yourself.net Interior Accessories Forum 0 23 Nov 2001 01:48 am
