2.2L CRD Diesel - Split Turbo Pipe/Hose
Old 03 Oct 2012, 07:02 am
Default 2.2L CRD Diesel - Split Turbo Pipe/Hose
I'm currently in the process of replacing a split Turbo Hose on my PT Cruiser.
I purchased the part from Chrysler PT Cruiser parts and accessories from the PT Company after getting the infamous "unknown" Fault code P01A4.
It's really great, because they even provide you with fitting instructions which can be found here:
http://www.ptcompany.co.uk/Assets/pdfs/Turbo%20pipe.pdf
Every thing was going great, until I tried to re-attached to "C-Clip". When I took it off, apart from the fact that there isn't very much room to see anything, the general area was completely covered in oil due to the split pipe, so I can't even say as how it was attached in the first place.
The instructions are great apart from this part of the job
"To fit the new pipe, fit the C clip first and check itís in the correct position - the wire should be visible when you look inside the pipe if its correctly placed in the locating slots (It can fit either way up)."
Firstly it says "the wire should be visible when you look inside the pipe", the C-Clip is way too big in diameter to fit inside the pipe and secondly if you check out the pictures at the bottom you can clearly see it on the outside.
it then continues to say:
"(the rim around the pipe sits flush with the rim of the
intercooler - if itís not flush itís not pushed home enough"
If the C-Clip attached to the pipe it prevents it from sitting flush.
I'm kind of at the point where I don't even see what this C-Clip does and there is next to nothing on the internet information wise regarding it existence.
I called up the guy at ptcompany.co.uk and he wasn't sure and referred me to the guy who wrote the above instructions but I'm not getting a response from him.
Any help at all would be greatly appreciated!
Thanks
Phil
Old 07 Oct 2012, 05:43 am
Default Re: 2.2L CRD Diesel - Split Turbo Pipe/Hose
Cue the Tumbleweeds.....
Old 07 Oct 2012, 09:37 am
cruserdad1976's Avatar
well just keep in mind 1 important thing
We DO Not Have Desiel In the USA
yep its
odd
stupid
makes no sence
pretty much should be aginst the law
but we dont so we dont know a lot about them
since we dont have any.
Turbo Intercooler pipe (hose) 767skyking Classifieds: For Sale/Trade 3 05 Sep 2011 02:21 pm
WTB Intake to Turbo pipe 05CruisergtHO Classifieds: Want To Buy 1 03 Aug 2008 10:43 pm
PT Turbo Diesel? raVerN8 General PT Cruiser Discussions 9 20 Mar 2004 08:48 pm
turbo to air box new down pipe amx1397 Vendors & Buyers Forum 5 13 Jan 2004 08:20 pm
Turbo Up Pipe Mean Green Turbo Performance 5 04 Jan 2004 05:11 pm
