PCV Valve On 2004 PT Cruiser GT
Like Tree16Likes
Old 18 Oct 2012, 12:33 pm
Default PCV Valve On 2004 PT Cruiser GT
I've been looking at post after post and am a little concerned about my car. It was blowing some blue white smoke and so I changed the PCV valve. The one I took off was hollow and the new one is exactly like all PCV valves I've seen in the past with a ball inside. In some posts I read there is no ball on the PCV for the GT and it's just an aspirator. Other posts indicate the possibility that the valve came apart. Can anyone say for sure which is correct? I'm having the turbo changed as that is what is suspect in the smoke, but we could be wrong. I've been told that the factory turbo is usually only good for a little over 60K, and I've got 94K. Thanks.
Old 18 Oct 2012, 01:08 pm
Default Re: PCV Valve On 2004 PT Cruiser GT
I would change the PVC first that info about the turbo is incorrect. It is highly dependent on how you treat your pt. If you're at wot all the time and don't give it run down time. Letting it idle or normal driving for ten minutes or so to cool the turbo. You could go through a turbo pretty quick. Check for side to side play on the impeller shaft. If tight look elsewhere first.
Yorgi1000 likes this.
Old 18 Oct 2012, 01:20 pm
I did change the pcv and that is my real question. Does it have a ball inside? It didn't cure the problem when I changed it. It has to be the turbo or valve seals/guides, but several experts have ALL said the symptoms point to the turbo.
BTW, I don't beat on my cars, and this one was just purchased as a replacement for a '03 GT that my grandson totaled. We had to change the turbo on that one shortly after 60K and that was when a turbo specialist told me that the turbo only last about 60K.
Old 18 Oct 2012, 01:29 pm
yes, it has the ball inside.
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 18 Oct 2012, 01:36 pm
Just don't see that kind of turbo failures as a whole on this forum. Most only join because of a problem of some kind.
Old 18 Oct 2012, 01:43 pm
What kind of explanation did he give you to substantiate this BS?
NitroPT likes this.
Old 18 Oct 2012, 05:35 pm
You just noticed that?
Busted_PT likes this.
Old 22 Oct 2012, 05:20 pm
Chris_TurbosUnleashed's Avatar
I can see the turbo only lasting 60k if it was not properly maintained with consistent synthetic oil changes, avoiding hot shutdowns, etc.
When properly maintained the turbo can last above the 200k mile range.
Chris-TU
OurPTGT and chromer don like this.
Chris Wright-Owner
Turbos Unleashed, Inc.
Phoenix, AZ Main Office since 1997
Vienna, Austria Europe Office Now Open!
Home of the 2 Year Warranty PT Cruiser TurboCharger
Chris@TurbosUnleashed.com
http://www.turbosunleashed.com
602-76-BOOST
602-76-26678
Old 22 Oct 2012, 06:02 pm
This thread has completely missed the point, but I'll give an update. First off, I was asking about the PCV valve, not the turbo. The valve cover was pulled and the insides of the PCV were indeed inside the valve cover. So the answer to my question is that the PCV on a turbo car is a PCV and not an aspirator as some on this forum had indicated. The valve cover seal was most probably the main culprit in my smoking. The tech also found two loose spark plugs and the wires were shot. We just got this car two weeks ago as a replacement for another PT GT that was totaled. The turbo was chewed up inside, so something definitely got in there, but it probably wasn't the source of my problem, but it's a brand new turbo now, so the car is fine.
As far as the turbo question about lasting 60K, I was told that when my OEM turbo went bad in our '03 PT GT. I was told that the quality of the Chrysler turbos wasn't the best. I'm only repeating what I was told and my turbo on the '03 was definitely bad. Hope this answers any questions. As always your mileage may differ.
Rick
Old 22 Oct 2012, 07:09 pm
Rick
I may have misunderstood. I took your 60k mile turbo life statement as the 'turbo tech' meant it was norm. Which i do not think it true with normal syn oil changes. I have upgraded to the MOPAR S3 turbo and pretty much beat on it everyday and 95k miles with no issues. The Mitsubishi MHI turbos used in the PT's have been around for a while so i don't think it's their lack of quality either.
Did you keep the bad turbo?
2004 pt cruiser dream cruiser series 3 LNBNDN General PT Cruiser Discussions 5 22 Oct 2012 07:55 am
PT Cruiser 2002 AC Expansion Valve? larcoelho Tech & Performance Forum 1 23 Aug 2012 05:05 pm
2004 Cruiser EGR valve? scoobydoodle Tech & Performance Forum 4 13 Dec 2011 07:52 pm
2004, 2.4L (non-turbo) Valve Chatter. Jabouty Tech & Performance Forum 2 15 Jun 2009 10:42 pm
Valve job for GT Cruiser? rush123ed Turbo Performance 3 25 Sep 2008 11:12 pm
