Non S2 performance
Old 24 Feb 2004, 09:03 pm
Default Non S2 performance
Ok, It appears as though S2 may not be in my plans anymore, SO, How do you get S2 levels of performance, 260hp or so from our cruisers. I held off buying S1 but it seems like that is the starting place,
Or should I just start with the stock PCM?
Will piggy back engine- fuel management work on our cars, if so which is the best way to go?
Give me a small back chevy and I will make hp, but with these new 4cyl, I am starting all over[:I]
Thanks,
Tom
Old 24 Feb 2004, 09:19 pm
S1 is a start, boost controller, aftermarket wastegate, exhaust, 3" downpipe with racepipe or high flow cat. This set up alone will push you past S2's performance. But it will also cost about the same as S2 if not more. You probably won't need an Engine Management till you get into the 300+ hp range but that's just my opinion.
R_K_GT
\'03 Electric Blue GT, silencers removed, K&N intake, Blanes Hood Struts, Emblems removed from rear hatch, Stage 1, Mopar BOV, Eibach springs, 18x8 Mille Miglia EV-R on 225/40/18 BFG g-Force T/A KDW 2, Eibach sway kit F&R, BTG Strut Bar, Chrome fuel door, custom 3\" cat-back exhaust with Magnaflow High-flow muffler, Blitz Dual Turbo Timer, Autometer Triple gauge pod, Autometer Ultra-lite with boost/vac, oil press and water temp gauges, Turbochargers.com wastegate, turboxs DSBC, Adams UCP, Dynoworks motor mounts with more to come.....
Old 24 Feb 2004, 09:33 pm
Are the S1 injectors good enough? What I am wondering is should I look into after market injectors and work with the stock PCM? I am not far from a place called EIP Tuning, they really lean towards VW performance, but are heavy into turbos, but from what I have been reading, the mopar pcms don't respond well to "normal" tuning tricks, True or false?
Tom
Old 24 Feb 2004, 11:13 pm
My experience in dealing with Dakotas is that you are correct.The Speed Density setup that Mopars use is not as flexible and not even close in regards to adjustability, as a compareable Mass-Air Flow System.
To me the best way to compare it would be like comparing the learning curve of a Texas Instruments Scientific Calculator to a 3Ghz Pentium XXXIV with 400Gigs of Memory and a lot better software.The Calculator does very well for what it was designed to do, but it will always do *exactly* what it was designed to do, and can not adapt, 'learn', and work with curves thrown at it.The New computer basically accomplishes the same things, it is just much more flexible in how it goes about it, and can work with varying types of input.
Hopefully that made some sense to you because it almost doesn't to me, but that's how i look at it.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 25 Feb 2004, 01:51 am
Tom
the 400 & 500hp srt's are using the S1 injectors and pcm, upgraded fuel delivery, and fuel management piggyback (psi-fi makes one, as well as the greddy emanage). I am on the verge of getting the emanage, but I keep backing out..
2003 Electric Blue GT
- Greddy E0-1, boost and AFR guages
- Custom exhaust: no muffler, side exit.
- Replaced air box with open end cone filter.
- Stage 1
Old 25 Feb 2004, 03:32 pm
You can't really just put in the bigger injectors without modifying the PCM to let it know what size it is dealing with. The S1 PCM knows that the larger injectors are there and orders a corresponding pulse width in response to input. Since we don't have a Mass Air meter to adjust, I know of no other way than modding/changing the PCM to achieve this.
Old 25 Feb 2004, 09:22 pm
Cal,
Thanks, thats what I was trying to figure out, I didn't know if the O2 sensor readings could cause the PCM to compansate for the larger injector and adjust for the difference. Like I said in other posts, I'm "old school" hp.
Tom
Old 26 Feb 2004, 03:13 pm
It will never run right. I am speaking from experience in the mustang arena with a Mass Air EFI system though. They always ended up running pig rich unless you got a chip burned or had the MAF programmed to compensate for the bigger injectors. The Speed Density EFI is a good performance system if you have access to the parameters and know what you are doing, but we don't have any tuners that have found a way to reprogram them from what I have read.
Old 26 Feb 2004, 03:38 pm
And you likely never will.Chrysler has always been extremely protective of their code, etc., to allow tuners to do what we need them to do.Almost to the paranoid level.
www.cybermopar.com
TripleJack
Old 28 Feb 2004, 05:25 am
If you use a fuel piggy back (like the greddy eManage), you can tune/adjust the injector duty cycle to compensate for bigger injector, higher pressure, additional sub-injectors, etc.. they alter the MAP sensor signal sent to the PCM to "trick" it into doing your bidding
- Stage 1
Hybrid Performance strangelove General PT Cruiser Discussions 1 04 Apr 2006 11:14 am
PT- 2.4 L Turbo: Performance Kit IS SOLD! JeffreyPT2003 Canada PT Forum 1 08 Mar 2005 07:44 pm
The JET PERFORMANCE CHIP is amazing... Gary04GT Tech & Performance Forum 9 13 May 2004 12:00 am
SRT-4 Mopar Performance Parts skylight PT Cruiser News and Rumors 13 23 Jul 2003 07:26 pm
Mopar Performance Parts Warranty Dalite Turbo Performance 0 07 Jun 2003 10:44 pm
