a little more power maybe?
Old 27 Feb 2004, 12:11 am
Send a message via AIM to 026TB4U
Default a little more power maybe?
i was told at the car show to remove a small piece of the rubber stripping in front of the air box that a vacuum is formed and actsd like poor mans ram air.I will give it a try,[:I] any thoughts
Old 27 Feb 2004, 10:27 am
Are you sure you aren't talking about removing the rear weatherstripping between the hood and the cowl?
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 05 Mar 2004, 12:33 am
yup, i am sure that it was in front of the air filter box
stage 1,manual bleed valve(18psi), k&n drop in , silencer removed, mopar bov and oh yeah its totalled now, waaaah
Old 05 Mar 2004, 01:50 pm
I've heard of the weather striping at teh cowl, but nothing ahead of the air box. If you find the weather striping more power to ya!
AC
If it doesn\'t fit get a hammer. If it still doesn\'t fit, get a bigger hammer. - Jesse James
Old 05 Mar 2004, 02:04 pm
I know with the Airraid box, they suggest you can remove a piece of the stripping in front of the box and that helps. I see no advantage in removing it with the stock box however. Where would you remove it, ahead of the box, in line with the box?
Homepage:
Old 11 Mar 2004, 03:51 pm
with the silencers removed i can see a little advantage . as for where to take it out my guess would be in front to the passenger side of the drivers side headlight
Old 15 Mar 2004, 09:06 pm
I am running an open filter intake with a 3" up-pipe. I removed a section of weather stripping from the front section. The opening lines up with my filter, and would most likely allow more air to the intake.
As i've said before, the air temp is important, but air volume is more important. I may have what you call a "hot air" intake, but in the 1/4 mile it is highly unlikely that there will be a big temp difference; but the fact that my 3" ram-intake is sucking more air will help me. If you drive hard for a while then go do a few 1/4 mile passes right after, then it will affect your performance due to heat soak.
My Cruiser is slow. I love the law.
Old 15 Mar 2004, 10:24 pm
I had a BTG CAI on my car, I removed it and went to the 1/4 mile yesterday, guess what?
Exact same times, I guess the PCM does really cutback to regain stock performance when it comes to mods before the turbo.
Patriot Blue 5-Spd, Stage I, Mopar BOV, BTG Intake, Custom 3\" Turbo-Back, Spring Mod, BTG Shock Tower Brace, Vogtland Springs, Koni Shocks, Eibach Sway Bars, Azev Type M 18x8.5 wheels, Ventus K104 tires, Projector Bi-Xenon Lights, Rear spoiler, Autometer Gauges, Illuminated sill plates, K&N Oil Filter, Mopar subwoofer. Mexico City. See pics: http://www.sportcarsforum.com/forum/viewtopic.php?t=715
Old 16 Mar 2004, 01:24 am
the exhaust gas temp is down 75 degrees from the day before at highway speeds. and all i did was remove a 6 inch piece of rubber stripping.
Power Seat? Musicman General PT Cruiser Discussions 7 20 Feb 2006 09:49 pm
Installing Power Door Locks PTRobert Sound and Security Forum 8 19 Feb 2006 11:36 pm
How to get power to my mp3 player & other concerns Doktor X Sound and Security Forum 3 29 Jul 2005 10:38 pm
ATF + 4 or 5 for power steering? quicksilverdon General PT Cruiser Discussions 2 21 Feb 2005 05:00 pm
Power Outlet Ed Lim General PT Cruiser Discussions 1 11 Jun 2003 09:40 am
