Installed Borla 2.5" Cat-Back Single Outlet
Old 28 Feb 2004, 09:12 am
Default Installed Borla 2.5" Cat-Back Single Outlet
For those of you contemplating going to 2.5" cat-backs as part of your S2 upgrade you might want to look at the Borla #14926 system. It eliminates the "octy-pipe" setup and has both tail-pipes exiting the drivers side. It is listed for the non-turboed PT but was a direct bolt-on for my 03 GT. I did not even have to cut the lower valence to make ropom for the twin tail-pipes. My car is lowered and there is still plenty of room for the 2.5" pipe as it goes over the rear-axle. All the Borla mufflers are a straight-through design and this thing doesn't sound any different than it did with my BTG muffler.
As far as the twin tail-pipes are concerned...there have been a number of threads concerned with the 1 3/4" octy-pipes on the Mopar cat-back for the turbos ( also made by Borla). Some of you have mentioned how the exhaust is always stronger on the short pipe side. The Borla 14926 system eliminates that problem since the twin 1 3/4" tail-pipes are only about 6 inches long before they dump into the twin chrome megaphones.
I can e-mail pics to someone if they want to post them here for me.
Deen
Old 28 Feb 2004, 11:12 am
hyracer,
I agree with you about the Borla 2.5" single exhaust dual tip (Part number 14926) being an easy bolt-on, and no problems even if the PT is lowered (I have the Eibach Pro-Kit springs on my '03 GT).
Check out this links for some pics I took during installation:
http://www.mooresmopars.com/GT-Cruis...ust/index.html
JC Moore, \'03 Cranberry GT, a.k.a. \"Zippy\"
http://www.mooresmopars.com/GT-Cruiser/index-gt.html
Stage1, BTG Strut Bar, Sun Hyperground system, Prototype Power CAI, no silencers, Eibach ProKit, Borla 2.5\" SSTL single w/dual tip, APC 2G Carbon Fiber Taillights, Chrome Fuel door, \'02 foldaway heated mirrors, OEM-style rear spoiler, Progress 22mm rear sway bar, TYC backup lights, Magnecor 8.5mm, stock plugs, MB Design \"Shifter\" 17x7.5 wheels, Goodyear Eagle F1 GS-D3 235/45/ZR17 tires
Old 28 Feb 2004, 04:06 pm
I does not fit the stock cut out. Why don't they make a single tip?
Old 26 Aug 2008, 10:55 am
Default Re: Installed Borla 2.5" Cat-Back Single Outlet
Talk about a difference, you can definately hear it now. makes the car actually come to life, it was way to quite before with the stock exhast.The install was very easy, however i had a lift so i could get all the way under the car.might be a bit of a challange to do with just jack stands. i followed almost all the directions, only thing i did different was to leave the mufflers on the Y pipe and take the unit out as a whole. Must have 2 people for this to work though.
MICHEEL
http://www.hookup-tonite.com
Old 26 Aug 2008, 03:17 pm
Welcome to the forum. Just a suggestion, buy a set of ramps, Wal- Mart has them. You will never believe how handy they will be.
Old 28 Jul 2009, 10:03 pm
demon666's Avatar
i see you have the rear part on the yellow ramps how do you get the car up like that on them there facing the other way .
picture with the purple ptc on yellow ramps.
I tryed to use some raps my coworker has but when i try to drive up on them they hit the lower bumper almost riping the hole bottom off not universal i gess...
Old 28 Jul 2009, 10:28 pm
I use a couple of pieces of wood in front of the ramps to get the front end up a little higher to clear the first part of the car.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 29 Jul 2009, 05:50 am
I don't think so. Straight-thru, to me means a straight line for the exhaust gas. As you can see from the picture, the muffler has 3 pipes - 1 in, 2 in parallel for exit. The exhaust goes from the center pipe to the side ones.
BTG exhaust - you can pick up each piece and look straight thru.
I'm not knocking Borla, just saying straight-thru it isn't.
used bassani single axle back flashbk2 Classifieds: For Sale/Trade 1 17 Oct 2005 01:48 pm
Back power window switches not working lumofny Tech & Performance Forum 3 16 Jan 2005 10:00 pm
OEM Back doors step pads installed PTRON Interior Accessories Forum 4 13 Jul 2004 01:59 pm
Heartthrob catback single exhaust Back Order Mean Green Turbo Performance 0 04 Feb 2004 02:14 am
Just spoke with Borla re: turbo cat back and... Cal Cruzer Turbo Performance 10 31 May 2003 01:42 am
