Not sure if its the Timing Belt??????
Old 23 Jan 2013, 09:52 pm
Default Not sure if its the Timing Belt??????
So I have a 2004 PT 2.4 Turbo that refuses to start. just turns over and over. I look to see if there are any codes and I get P0340 Cam shaft position senser positive. I look to see if there is spark and there is none. Took the senser off to see the if the piece that spins on the cam is spining when i crank it. No spin at all. The car was being driven about 30mins on the freeway. When my sister gets to a stop light, the car stalls. tring to get going agian and cant. The car has 120,000mile, we bought it at 96000miles and the previous owner said he changed the timing belt. The car needs to be running ASAP. My Sister use the car to get around in college. If we i dont get it working soon, Ill have to give up my car.
Old 23 Jan 2013, 10:11 pm
Ray_Dockrey's Avatar
Default Re: Not sure if its the Timing Belt??????
If its not spinning then the timing belt has broke.
Old 23 Jan 2013, 11:41 pm
Great. Ok i ve done lots of work on cars the need to have the motor mount removed. Just how hard of a job are we talking about? and do i need to remove A/C components?
Old 24 Jan 2013, 12:11 am
generally yes you need to decompress the AC and remove the components, there is a way to remove the mounts and twist the motor, but thats kind of sketchy.
A timing belt can be done in about 6 hours by someone who knows their way around a PT. upwards of 12-17 if its your first time.
Make sure to lock the cam gears in place!!!!
Make sure when you re-do it that the timing marks are perfectly lined up , that it is at TOP DEAD CENTER, then rotate the crank 2 full rotations.
After you install the belt its always best to check it with a timing light.
You can pick up a haynes manual for $24 at a local autozone and it will give you the step by step instructions on how to do it :-)
Old 24 Jan 2013, 09:59 am
There are a few threads pertaining to this subject.
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
ever replace timing belt in a pt cruiser
Replacing the timing belt 2.4L (without a lift!) -Detail instructions
Timming Belt Change Help-Getting to tensioner
Timing Belt Change Hints and Tricks (Picture Warning!)
These might give you a helping hand. And also there are many more here and on google. And of course you have us.
Old 24 Jan 2013, 10:52 am
Just a few eh :-p
Old 24 Jan 2013, 11:09 am
Originally Posted by pluminator View Post
Just a few eh :-p
You liked that did'nt ya? Come on you know you did! ha ha he........
Old 24 Jan 2013, 11:12 am
I have a tip as well!
Do not cut off the timing belt with scissors!. I've seen that done and it doesnt work out all hunkey dorey haha
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
Timing Belt quicksilverdon Tech & Performance Forum 12 18 Aug 2010 01:24 pm
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
