Installation of new coil
Old 04 Mar 2004, 05:03 am
Default Installation of new coil
Need some advice on how to install a new coil on PT GT. Any help would be appreciated.
Old 04 Mar 2004, 09:10 am
IGNITION COIL
REMOVAL - 2.4L TURBO
(1) Disconnect the negative battery cable.
(2) Remove the throttle control shield.
(3) Remove the throttle cables from the throttle
body lever.
(4) Remove the throttle cable bracket and relocate.
(5) Remove the spark plug cables from the ignition coil.
(6) Unlock and disconnect the electrical connector
(7) Remove bolts from ignition coil. Twist coil to
remove 2 of the boltsfrom the coil before removing it from
vehicle.
(8) Pull coil up and out by the throttle body side of the intake
manifold.
INSTALLATION - 2.4L TURBO
(1) Install the coil on throttle body side of the
intake manifold, rotate down past the throttle
body to the valve cover.
(2) Connect and lock the electrical connector to the ignition coil.
(3) Install bolts to ignition coil. Twist coil to install 2 of the
bolts to the coil after installing it to vehicle.
(4) Install the spark plug cables to the ignition coil.
(5) Install the throttle cable bracket.
(6) Install the throttle cables to the throttle body lever.
(7) Install the throttle control shield.
(8) Connect the negative battery cable.
NOTE: Check and make sure that throttle body and
attachments will not contact ignition cables.
2002 Inferno Red PT Limited
Mercedes Wiki
Old 04 Mar 2004, 09:34 am
LAF LAF is offline
After just doing mine I would remove the manifold if there is a next time. The time it takes to do that is worth what you make up fussing with the 4 nuts on the coil.
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge.
Elbert Hubbard (1856 - 1915)
2003 Electric Blue GT-30,000 Miles on the clock
Stage 1, Greddy Profec II B. Turbo Chargers Wastegate set to 13#. Forge Motors BOV (Blue of course). Brand AMX Intake/AirCooler Pipes/K&N Cone with Snorkel to Fender well, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3” down pipe with high flow cat, BTG axle back exhaust, Rear Spoiler. Russel Brake Lines/Hawk Brake Pads/Power Slot Cyro Rotors on a four corners
Support Your Right to Arm Bears
Old 04 Mar 2004, 12:00 pm
Just remove the manifold, leave the cables alone. This job is a snap.
03 Steel Blue Pearl Turbo, Stage 1, Mopar BOV, Magnaflow performance muffler, My Air Box mod., AMXpipe W/K&N filter, LED lighting,PT Tunning rear lowering springs & BGT Strut tower brace, Hankooks Ventus tires, Rage Motif 17 in. wheels. Tribal pinstrips by Palmer (who else), Color match paint by Etouchup.com, Plugs and wires by Sparkplugs.com, http://members.cardomain.com/rodrungtpt
Old 04 Mar 2004, 12:39 pm
Thanks guys for all your help. We have a great bunch of guys on the forum - you're awesome!!!!!!!!
<b><font color=\"red\">2003 LT ALMOND GT</b></font id=\"red\">
<font color=\"blue\">MODS:</font id=\"blue\">
Stage I, Custom Pin Stripe, Rear Spoiler, BTG Polished Strut Tower Brace, Borla 2.5\" CAT Back Dual Exhaust, and AirAid Intake System, Polished Front & Rear Sill Plates, Chrome Antenna Bezel w/10\" Chrome Billet Antenna, Mobil 1 and K&N Gold Filter, \"Flame\" 3rd Brake Light, \"Streamline Design\" PT Cruiser Visor, Rear Shelf Graphics and Dash Dots on Steering Wheel, and MGW \"GT\" Auto Shift Knob,Chrome Door Lock Pulls, Chrome Billet A/C Knobs with Acrylic Red Inserts, Chrome Oil Cap, Chrome Dip Stick, Chrome Radio Knob, Blane\'s Hood Lift Kit. Chrome Raidiator Coolant Bottle Cover, Timing Belt Housing Cover, Shock Tower Covers w/Nuts, Power Brake CYL Cap Cover, Windshield Washer Cap Cover, A/C Line Connector Cap Covers, A/C Check Valve Cap Covers and Radiator Cap Cover. \"GT2\" Rolo Red Calipers, Magnecor 8.5mm Spark Plug Wires - Red, Red Wire Looms, Billet Aluminum Steering Wheel Caps (4), Chrome Coin Tray Trim Cover, Chrome Shifter Bezel Tirm Ring, Yoko AVID V4S - 215/50/70\'s, TYC Euro Style Back-up Lights, and Screamin Demon Coil
Old 08 Mar 2004, 07:29 pm
Don't forget to update your sig[^]
Old 08 Mar 2004, 11:15 pm
What benefit does installing a new coil have?
Homepage:
Old 09 Mar 2004, 03:38 am
If it's the msd coil it works as a weight reduction, his wallet is alot lighter now! The MSD coil is a red stock one. You actually have to add on an ignition box to get any gains.
AC
If it doesn\'t fit get a hammer. If it still doesn\'t fit, get a bigger hammer. - Jesse James
Final manual boost controller installation Ian-PT-GT Turbo Performance 85 05 Mar 2010 03:04 am
Shifter Installation proxeyed Tech & Performance Forum 4 18 Feb 2008 12:30 pm
Screamin' Demon Coil, LiveWires & Champion HighFive Tech & Performance Forum 2 27 Mar 2007 08:57 am
Lowering Springs and/or Coil Over Shocks tom-t-rifik Turbo Wheels/Suspension/Handling 1 28 Jun 2004 05:57 pm
Screamin Demon Coil and Howell Automotive snakepitt1 Tech & Performance Forum 4 21 Jun 2004 11:44 pm
