Head porting?
Old 05 Mar 2004, 05:43 pm
Default Head porting?
Would you?
I'm thinking about it, what do you think?
Old 05 Mar 2004, 05:58 pm
Good porting is not cheap. Good porting will increase flow on both the intake and the exhaust side. Even better, on the exhaust side with the Turbo, make sure you get port matching. With the flow increased, the horse power goes up.
Mike
Old 05 Mar 2004, 06:03 pm
Extrude Hone.........mmmmmmMMMMMMMMmmmmmmmmmm........
Not cheap either.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 06 Mar 2004, 06:30 am
See Bob Stockums' site.
Tom
Old 06 Mar 2004, 12:11 pm
i always woundered why all the big dogs running 18 psi with all the exhaust intake.... didn't have that done just never asked. sounds good to me.
\'03 pt gt s1 mopar bov auto patriot blue
1925 modle t pulling truck w/864hp 673ft/lb 2002 harley, 1998 zrt 600 cat
http://cpatrucks.org/members/endres.html
Old 06 Mar 2004, 02:35 pm
Ant Ant is offline
In addition to Bob check out Nick at NRGY Heads! His work is incredible!. A true perfectionist, and his customer service is unparalelled. If you speak with him let him know I referred you.
http://www.nrgyheads.com/
Anthony
PT powered PT with:
Fully built HRC Turboed 2.4: Wiseco pistons, T2 rods, Port & Polished head (Bob Special) with oversize Stainless Steel valves, #14 Crane Cams, AF/X UDP, No balance shafts, Custom 3\" downpipe, 3\" hi flow exhaust, Ported GT intake manifold, Bored Throttle Body, 30 lb injectors, Water/Alc. injection
Old 06 Mar 2004, 04:57 pm
Send a message via AIM to 03baggedturbo
Two things on that..
One) Make sure you do go to someone that knows what they are doing. I have been racing Hondas for years and have seen way too many times soneone spending a lot of money and actualy loosing HP because they go to somone that isnt experianced. Bigger isnt always better.. it's flow..
Two) Make sure you do port match the intake manifold or it realy isnt worth doing.
If and when you do this I am sure we will all be very interested in the results..
ADAM
Old 06 Mar 2004, 06:39 pm
ADAM
Yes to everything Adam said. Bigger is not always better. You can move the power curve so far up the RPM scale that the car becomes undrivable in the street. Oh, and port match to the exhaust manifold too. Especially with a boosted engine. The exhaust needs to flow like goose crap through a tin horn.
Old 07 Mar 2004, 09:32 am
Save your money and buy the Turbo off of the SRT4 Stage 3 when it comes out. Of course that will require you to already have the S2 components installed on your GT.
Deen
wire harness for new head unit ckanders General PT Cruiser Discussions 3 28 Mar 2007 03:31 pm
panasonic mp3 head unit - very good Tw3NTy0n3 Classifieds: For Sale/Trade 0 05 Sep 2004 06:26 pm
Head unit fixing / blanking / mounting kit ededdneddy Sound and Security Forum 0 23 Jun 2004 09:58 pm
Solid Head bolts for the GT Turbo? Airbillster Stage Turbo Kits 7 26 Dec 2003 11:45 am
Head bolts for the Turbo? Airbillster General Turbo Discussions 11 16 Dec 2003 11:05 am
