Removed my mbc with unexpected results...
  #11 (permalink)
Old 16 Mar 2004, 04:06 pm
My PT spins crazy with t/c on or off if I let it loose. When it spins with t/c on it cuts boost (most of the time), when it spins with t/c off it doesn't cut boost (most of the time).
I've also noticed with the t/c on if it spins and cuts boost it usually will not raise it to the normal max once stable conditions are met.
With the t/c off it will almost always go back up to max after.
I plan on getting to the dragstrip this year for sure. I also plan on getting some better rubber this spring.
Louis
03 Black PT Turbo
02 Red Aztek GT AWD
United Kingdon Calendar Results CREWZIN General PT Cruiser Discussions 2 15 Sep 2006 09:49 am
California Speedway Results September 18th PTGT_Boy General Turbo Discussions 1 19 Sep 2004 01:33 pm
New PCM results GTSteve General Turbo Discussions 29 21 Nov 2003 05:01 pm
Unexpected downshifts downhill on GT w/Autostick KevinM Turbo Performance 4 30 Sep 2003 05:04 pm
Jet Preformance Chip: Test results 2coolPT Tech & Performance Forum 22 08 Feb 2003 02:37 pm
