OVERHEATING AT A LOSS
Old 25 Mar 2013, 08:32 am
Default OVERHEATING AT A LOSS
I tried everything from flushing radiator, new t-stat, new reservior, fans working, and water pump. I was told there was air trapped in the radiator i tried bleeding it out didnt work. Yesterday i was letting car idle trying to bleed air out and i saw water pouring out the bottom. I looked and looked and could not see where it was coming from. I put the radiator cap on and close the bleeder and leak stops. Turn the car off no leak. I drove it about 6 miles all was ok then it started to over heat again. It got so hot it blew the reservior cap off and was boiling in reservior. I let it cool and filled it up again and did the same thing over and over. I dont see a leak, water on the ground but idle with cap off water comes out from somewhere cant see it. I love my pt but Im to the point of selling it. 2005 pt convertible with turbo. If anyone knows plz i will listen.
Old 25 Mar 2013, 07:52 pm
needmoretoys's Avatar
Default Re: OVERHEATING AT A LOSS
Just because it's a new tstat doesn't mean its not bad. I would check it out. Maybe it's upsidedown. Not sure if that can be done I 've never seen mine.
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 26 Mar 2013, 07:45 am
Theres only one way to install a t-sta. thats not the the problem. Im just going to sel the the pt.
Old 26 Mar 2013, 11:29 am
SpoolinPT's Avatar
i have also seen rad caps get cracks in the seals and cause this issue. even a aged cap can have a shrunken seal. if they don't fit perfect do to age they will allow air to be sucked in threw cap.
04 pt limited turbo. port n polished td04. agp wastegate. s1 ecu. s2 cams. greddy bov. open exhaust. lowered on 1g neon springs. 18" asa's
Power and MPG Loss Smurfy Tech & Performance Forum 10 28 Jun 2011 08:31 am
Loss of power slcpunk Tech & Performance Forum 9 15 Apr 2009 12:51 am
How Much Horsepower Loss.... BB Turbo Performance 12 30 Jul 2008 08:55 am
Power loss littleblueGT Turbo Performance 3 11 Apr 2006 11:45 pm
Power Loss LoboMXGT Turbo Performance 2 15 Aug 2005 04:00 pm
