In need of piston
Old 07 Jun 2013, 04:53 pm
Default In need of piston
I am in bad need of a piston for my 05.
Can someone please help
Old 09 Jun 2013, 09:56 am
Default Re: In need of piston
PM Uptown or check ebay. might also ask at srtforums.com
you need one that still has the connecting rod on it. the pin is press fit, meaning you will not be able to swap the rod yourself. even an experienced shop may crack the piston trying to press the pin.
when you install it, the backs of the bearings should be dry and only the faces should get assembly lube or oil.
Old 09 Jun 2013, 09:01 pm
Thanks a lot for your reply,did not know about the lube on one side
Old 09 Jun 2013, 09:04 pm
P.S.what is the diff.in a turbo piston and a non turbo
Piston for turbo Bobbykeith Classifieds: Want To Buy 0 03 Jun 2013 01:04 pm
Piston Misfire Connie Tech & Performance Forum 1 16 May 2011 05:24 pm
Piston Conecting Rod loadedchainsaw Tech & Performance Forum 3 02 Mar 2011 07:12 pm
