my opion of my new intake
  #11 (permalink)
Old 01 Apr 2004, 08:07 am
Tommy, when are you going to take it to the track and get some Qtr. mile runs. You are running Stage 1 (235 HP) and if what you say is true the addition of 30 HP would equate to a 13.85-13.95 ET.
Also what were the outdoor temperatures when you made your runs/tests?
Since our cars are speed density controlled the maps will adjust for higher/cooler air temps. You WILL make more boost in the summer or on warm/hot days than you will on cool days since the computer is trying to keep the boost (HP) in design limits. I have made no recent changes to my Turbo and mine also boosted higher last summer than it does now...and I expect it to do so again on any given hot day.
If you indeed can run high 13's or even 14.0's you can count me in for buying his setup.
Deen
  #12 (permalink)
Old 01 Apr 2004, 02:52 pm
I'd agree with Ian,
Piping air through a small tube requires a lot more work than through a wider tube. Less resistence, increased flow.
Plus I'm sure there's a thermodynamic issue with the air charge coming from the intercooler into a wider cooler tube to the TB.
Even if the PCM corrects, it will still run more optimally from the standpoint that it is a more efficient system.
Looks awesome in the blue, tommy.
Show car stuff, replacing the ugly ribbed OEM charge tube.
My boost gauge, I can hit 12-13 WOT at this time of year, although that is about as high as I have gotten. Whether I need a 15-16 spike, but less work=less strain on turbo=longer life=less money=happiness.
Homepage:
  #13 (permalink)
Old 01 Apr 2004, 08:13 pm
Send a message via AIM to tthrift
Deen
hey Hyracer, it was in the 60's on the day that i installed the pipes, but when i drove the car home from work i couldn't boost that high and one hour after i got home i did the installation.So for a total of 2 hours befor i drove the car again the i had higher boost levels.I don't have an exact answer why my boost levels went up but i am very pleased.
thanks tommy
  #14 (permalink)
Old 02 Apr 2004, 12:40 am
The pipes will prevent spike over rubber, but if there is an increase in hp it will come from the intake and there is no intake that will make 30 hp. the non expanding will cause th hp to go up because the boost goes to the enging instead of blowing up the hosses like a balloon, any intake will help, some more than others. The metel pipes don't flex so you will not get the flex as you do with the stock hoses= up in boost =up in hp. The new pipes look small what size are they. How much are they?
doit
  #15 (permalink)
Old 02 Apr 2004, 01:01 am
They are 2.5".
No restrictions unlike the stock intake.
I haven't taken apart my charge pipe, but somehow I doubt interior diameter is very broad.
As a thought, there would not be an adverse issue putting in hard pipes? I can't imagine there would be.
Homepage:
  #16 (permalink)
Old 02 Apr 2004, 12:10 pm
GTBlue, welcome to the forum!
2002 Inferno Red PT Limited
Mercedes Wiki
  #17 (permalink)
Old 02 Apr 2004, 10:06 pm
Send a message via AIM to 03baggedturbo
I am going to say a couple things but I dont want to get into a huge discussion about weather or not people think whatever..
The metal UCP does make it so your boost levels are more consistent because of the lack of flex in the silicone stock pipe.
The stock UCP bends dramatically at the bottom where bends around the battery.. The way I made the UCP is gets rid of that harsh bend.. Look from under your car or reach and feel it.
I realize that a lot of people do have different brand intakes so I made "8" Just UCP with no BOV.. I sold 5 of them.. two in candy red and 3 in candy blue (As soon as the powdercoater runs those two colors.) One was using a HKS BOV, one using a Greddy BOV so I will have a couple more pics to show you soon..
I do not know how my UCP will react with other intakes.. Basically all open air filter intakes are made the same.. As straight of a pipe as you can make with an open air filter.. Debates on filters in the stock air box.. I dont know..But I guess we will all see when these people receive there pipes.. I realize that this product is new and people are skeptical I would be if someone posted something like this.. Lets just wait and see what happens when more and more people get this product and let it speak for it self..
Mike is helping me make my web site. It will be up in a few weeks with a page on instructions for the install with pictures, other cool stuff.. Prototypepower.com
Thank you
ADAM
ProtoTypePower
  #18 (permalink)
Old 03 Apr 2004, 04:49 am
Using a metal charge pipe works with other blown applications, I think this is a major contibution to our cause. Hope to get one.
  #19 (permalink)
Old 03 Apr 2004, 10:06 am
Adam,
How much for just the UCP (no BOV flange) in candy blue?
Thanks,
Scott
\"If you choose not to decide, you still have made a choice.\"
  #20 (permalink)
Old 03 Apr 2004, 12:11 pm
I posted a reply to prices on the vendors section.. I don't want to get into trouble or get this post moved for talking prices..
Thank you Tommy and all others that have the system that are telling there others about it..
ADAM
3.0-inch AGP Intake strangelove Turbo Performance 7 21 Oct 2006 03:52 pm
MOPAR Cold-Air Intake Review blueberrygt Turbo Performance 12 23 Sep 2005 01:04 pm
3" cold air or 2 1/2 " hot air intake ?????? amx1397 General Turbo Discussions 12 25 Jan 2004 12:35 pm
pt tuning intake VS Ebay intake gt_tuner Turbo Performance 8 21 Jun 2003 11:41 pm
AIR INTAKE FROM AMX1397 amx1397 Turbo Performance 6 03 Jun 2003 10:22 pm
