Boost Question
Old 04 Apr 2004, 10:54 am
Default Boost Question
I have looked at boost controllers for more perforance, but I believe that you dial in a setting and that's your boost. Our stock controller, if I am correct has a variable boost depending upon data received by our chips. If so, does this data show what the boost is to the turbo and if it does could this boost sensor be reprogrammed or tricked into showing 2 lbs. under actual? If so, we would have the advantage of variable boost, yet higher boost throughout the range than stock. Possible or Impossible?
Old 04 Apr 2004, 02:22 pm
Why? You want maximum boost at WOT and the only thing that will limit that is available fuel and the design restrictions of the engine.
The pcm controls torque output via the waste gate. The only way to increase torque output and HP( without being reeled back in) is to bypass the pcm control of the wga. The only real way to increase boost would be the installation of a boost controller and bypass the #2 solenoid. Unfortunately this affects part throttle drivability, basically too much boost to fast which leads to "flutter","surging". However, you can use a system that only bypasses the # 2 solenoid under WOT. This has been discussed in length on this board and the srtforums board. Try searching dsabc or dual stage automatic boost controller.
A higher rev limiter would be nice!
Old 04 Apr 2004, 09:27 pm
Thanks for replying. My thoughts were that we are very seldom at WOT, at least I am. But it would be nice to have more boost available on demand rather than stop and dial in the boost controller.
Please see Forum Guidelines regarding signature image sizing.
'05 max boost question Topless in Cali General Turbo Discussions 4 12 Apr 2005 07:57 pm
Mopar Boost Gauge install question ksquared11 General Turbo Discussions 1 19 May 2004 02:05 am
Boost question for Toronto area GT owners NorthernPT Turbo Performance 3 10 Apr 2004 12:48 pm
Final manual boost controller installation Ian-PT-GT Turbo Performance 83 10 Jul 2003 11:57 pm
Boost gauge install question NorthernPT Turbo Performance 14 21 Apr 2003 11:35 pm
  Debt Consolidation | Debt Consolidation | Submit articles | Novated lease | Debt Consolidation
