Needmoretoys = Needmoreboost
Old 06 Feb 2014, 08:41 pm
needmoretoys's Avatar
Default Needmoretoys = Needmoreboost
So I installed my FM waste gate actuator today. It was not fun. I had to cut the bracket that holds up the intake manifold. After a little cursing I got it all buttoned up and now I have to set it. I wasn't sure how to do it so my buddy at work is going to show me. What a crappy ride to work. I could only boost 5lbs. (It is part of the install) I do have the need for speed , it;s something I learned to live with. So tomorrow when I get up I will adjust the actuator and see what happens. I am excited to see what I can push out of a stock turbo.
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 06 Feb 2014, 09:31 pm
InfernoGT's Avatar
Default Re: Needmoretoys = Needmoreboost
Sounds great! Keep us posted!
2006 PTGT with 5spd. ~60k miles
Old 08 Feb 2014, 12:31 am
Are you keeping it on PCM controlled boost I take it?
1999 Dodge Neon Coupe. DOHC 5 speed
2005 Crossfire SRT-6
2005 PT Cruiser GT 5 speed. 1 of 21 (SOLD)
Old 10 Feb 2014, 12:12 pm
apexanimal's Avatar
Send a message via AIM to apexanimal
it's a great wga...
you have gauges (boost/afr)?
'03 GT 5spd: Stage 1+
http://www.cardomain.com/ride/2272425
http://www.ptboutique.com
Old 10 Feb 2014, 01:37 pm
computer controlled yes. with a DSP.
I have a boost gauge but no wideband yet.
I have way too much boost I had to turn everything down on the DSP. Way to much knock.
Lenny
Old 10 Feb 2014, 02:55 pm
Yeah KR is bad. How much were you getting and what kind of octane are you running?
Old 10 Feb 2014, 06:12 pm
I think it was 4. I'm running 93 octane. I hit 18lbs in no time. It felt good till 4500. I'll get it dialed in. I can't wait. I need to log the DSP through my laptop to get all the right PIDS.
Lenny
Old 11 Feb 2014, 01:16 am
Cold weather where you are at? I always noticed I would get some KR when the weather got cooler and the crappy winter blend gas came in. 4 isn't that bad. Anything over 6 is pretty bad. Or if you actually hear it audibly lol. But you always want to shoot for 0. If you get 1 or 2 its sometimes false knock.
Old 11 Feb 2014, 10:47 am
I'm in Maryland. It's been real cold here. I do hear the know. It keeps me out of boost. I can drive the car. I need to turn down the WGA then I should be ok for now. When it get nicer out I'll see if I can tweak it a bit. I really need a wideband so I don't blow this thing up.
Lenny
Old 12 Feb 2014, 12:24 am
Yes get a wideband. They can be had for around $150 shipped on eBay. that is for a AEM Uego. Way cheaper then a short block. Winter is the time to be running lower boost. So NeedMoreToys = NoMoarboost!
NeedMoreToys Artworx Chromenut General PT Cruiser Discussions 5 09 Jul 2013 07:57 am
Needmoretoys(Lenny) Pictures (about time) needmoretoys General PT Cruiser Discussions 9 04 Jul 2013 09:23 pm
