anyone selling profromace parts??
Like Tree5Likes
Old 08 Feb 2014, 01:40 pm
Default anyone selling profromace parts??
i have a 2005 pt cruiser gt turbo, auto stick with 139000k looking to add some power. air intake,headers,diablo sport tuning. name your prices please have pics
Old 08 Feb 2014, 01:48 pm
Default Re: anyone selling profromace parts??
K&N drop in as good as it gets on Turbo. Header to short to be a help. Stage 1 and the other are the two best gains per buck.
Old 08 Feb 2014, 01:50 pm
Well this is a different approach to finding "Hot Rod" parts! Make the sellers come to you?
Old 08 Feb 2014, 04:07 pm
Personally over the years I've gotten all of my profromace parts from either PROFROMACE PARTS-R-US or PROFROMACE CITY. They've never let me down.
There is one airfilter/intake unit that stands tall above the others, but everyone seems to recommend the drop-in K&N so I will also. The K&N is a fine piece and you can get one at almost any local parts store (Pep Boys, Advance, etc.).
As far as the header goes DCR makes an excellant tubular turbo header/manifold for the SRT-4's and it WILL bolt onto our PTs. It's designed for middle to high rpm performance gains so it won't be the best choice for the street. That's up to you. It's just a little bit pricey, but you get what you pay for.
Pro Series Turbo Manifold...add options for complete Kit - Darrell Cox Racing - (Powered by CubeCart)
[IMG][/IMG]
I'm joking about the header, it's not for you on the street.
Either the Chrysler STAGE 1 or the DST or DSiT will work fine as far as PCM enhancenents. Frankly, if I were in your place, I would go with the STAGE 1 because it will improve your ATX's performance while still taking some of the strain off of it (less slip at shift points) and with your mileage your tranny will need all the help it can get.
That brings up my final point, adding more power at that number of miles is--------well.
Jerry
OurPTGT and Busted_PT like this.
Old 08 Feb 2014, 04:32 pm
I've got performance engine oil, oil filters, NGK spark plugs and wires, transmission fluids, air filters, brake fluid, coolant and coolant additives, and fuel additives. All at wholesale.
2005 CHRYSLER PT CRUISER 2.4L 4-cyl Engine Code [E] Turbo
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......API*[1]
Maximum Performance SAE 5W-30 Signature Series 100% Synthetic Motor Oil (ASLQT)
Performance Plus XL 5W-30 Synthetic Motor Oil (XLFQT)
Performance OE 5W30 Synthetic Motor Oil (OEFQT) All TEMPS......5W-30
Manual Transmission,GET288 (5-SPD)......AP4
All TEMPS......
Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid (ATF) (ATFQT)
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT)
Automatic Transmission,41TE......AP4
Automatic Transmission,40TE-AE......AP4
Fluids
Power Steering Fluid......AP4
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT) [2]
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN) [3]
Clutch Fluid......HB
[1] Use motor oil that is formulated to meet Chrysler MS-6395.
[2] ATF+4® Automatic Transmission Fluid
[3] Hydraulic Brake Fluid, DOT 3
P/N 04318080AB or 04318081AB, meeting MS-4574
FILTERS:
Oil Filter 25,000-Mile Ea Oil Filter (EAO34)
Oil Filter WIX 51516 Oil Filter
Air Filter WIX 46699 Air Filter
Transmission Filter WIX 58934 Trans Filter
NGK PLUGS AND WIRESETS:
GPSERIES PLUG LZTR5AGP
IXIRIDIUM PLUG LZTR5AIX-13 NGK2314
PREMIUMPLATINUM PLUG PLZTR5A-13
VPOWER PLUG LZTR5A-13 NGK4306
WIRESET WIRESET RC-CRX065
WIPER BLADES:
Blade Class Driver Passenger Rear
ExactFit T201 T211 T161
NeoForm T16200 T16210 T16160
Winter T37205 T37210 T37160
CHASSIS LUBRICATION:
0 Fittings, 0 Plugs
CAPACITIES:
Engine, with filter..........5 quarts [1]
Cooling System, Initial Fill..........7 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 41TE Initial Fill..........4 quarts
Automatic Transmission, 40TE-AE Initial Fill..........4 quarts
Automatic Transmission, Total Fill
4 speed 41TE..........8.6 quarts
4 speed 40TE-AE..........8.6 quarts
Manual Transmission, GET288 (5-SPD)..........3.8 pints
[1] After refill check oil level.
TORQUES:
Oil Drain Plug.....20 ft/lbs
Manual Transmission
Fill Plug 29-35 ft/lbs
Drain Plug 29-35 ft/lbs
OTHER TOP QUALITY PRODUCTS:
Mothers® Car Care Appearance Products
By-Pass Oil Filters
Diesel Fuel Additive Concentrate
Cold Flow Improver
Cetane Boost Diesel Fuel Additive
PI Performance Improver Gasoline Additive
Product Recommendations and Drain Interval Chart
Old 08 Feb 2014, 04:56 pm
Re: anyone selling performance parts??
So keeping with what the OP is actually asking! These are actual members actively participating on a PT Cruiser forums and offering performance related parts specifically for PT Cruisers.
There is a number of technical information threads as well as lots of pictures on the http provided. I believe you will need to contact them for exact pricing on what they offer?
Performance valve train parts;
NS PT CAMSHAFTS another idea?
Performance Head;
Thumper Performance
MOLE's Turbo Performance
Mole Position
Old 09 Feb 2014, 01:34 am
I personally would never go the BWS route. Have not heard that much good info about him.
https://www.google.com/#q=mole+srtforums
If you plan on forking over money for a BWS, might as well save a little extra coin and go big turbo. All depends on how much power you want to make.
1999 Dodge Neon Coupe. DOHC 5 speed
2005 Crossfire SRT-6
2005 PT Cruiser GT 5 speed. 1 of 21 (SOLD)
Old 09 Feb 2014, 01:44 am
Not necessarily so. May I suggest to call and talk to DCR about them for street use and not so much what other forums and there reviews are!
DCR (Darrell Cox Racing
Welcome to DCRSRT.com - Darrell Cox Racing - (Powered by CubeCart)
Old 09 Feb 2014, 02:12 pm
"May I suggest to call and talk to DCR about them for street use"
Of course they are going to tell me everything I want to hear. They have been doing that forever. I will never buy anything from DCR. I have been in the 2.4 turbo world since 2005. I know quite a bit about DCR and I do not trust them due to the horrible reviews and a few locals that have bought items from them. I rather trust reviews from people that have bought it then their word. Their "anti-surge mod" and "ramp mod" More snake oil. They show no data or results.
Also the "red sled" has no affiliation with DCR anymore. Since the owner couldn't get parts in a timely fashion.
A local has the 2.6 stroker motor in his SRT-4. The tone ring broke within 2k miles.... His car is not the only car for that to happen too.
And that picture showing the stock turbo from their site, did you just take that screen shot off their site recently? Because I cannot find their modded stock turbo at all on their site now.
http://www.dcrsrt.com/index.php?_a=category&cat_id=11
I suggest anyone looking to buy something from DCR to research before they do.
Here are BETTER alternatives:
http://www.ffperformance.com/
http://www.forwardmotioninc.com/html/about.htm
Old 09 Feb 2014, 03:41 pm
um ...that Turbo pictured from the side is mine and mostly my work!
Parts compatible years - 2003 parts on a 2006? Wutliss420 Tech & Performance Forum 1 22 Feb 2013 03:25 pm
Selling your old parts KingKole02 General PT Cruiser Discussions 6 28 Feb 2006 11:34 pm
Selling my performance parts retroman715 Classifieds: For Sale/Trade 5 20 Dec 2004 12:50 am
YearOne selling PT parts Stephen R. General PT Cruiser Discussions 9 09 Dec 2003 07:35 pm
