Need Help
Old 22 Mar 2014, 09:37 am
Default Need Help
OK i have a 03 pt cruiser turbo, i need to know what a part is called it is a plastic screw that has a black top that a hose attaches to, it is located on the engine by the oil cap. It broke and need to replace it just dont know what it is called. Thank you to anyone that can help out.
Here is a link of the motor it the part next to the oil cap with the hose attached
http://www.google.com/imgres?imgurl=...art=14&ndsp=20
Old 22 Mar 2014, 11:42 am
Default Re: Need Help
Directly above (toward rear of the car) the oil cap?
It's the PVC valve.
Depending on year, it either screws in or is a push-in 1/4 turn.
Old 22 Mar 2014, 11:58 am
The one above the oil cap is the PCV Valve
I am not 100% sure but I think the one below the oil cap and next to the thermostat is the Coolant Temperature Sensor.
Grey/black Plastic valve cover is screw in.
Hmm that is the first time I have seen an aluminum with a screw in not twist PCV valve? Well what you know my "thing" learned today!
Old 22 Mar 2014, 06:18 pm
thanks everyone that helped alot thanks again
