Make it faster
Like Tree6Likes
Old 23 Apr 2014, 10:14 am
Send a message via Skype™ to jkgx777
Default Make it faster
Hey guys i know There is probably a good bit of threads out there on this topic but none for my mods basically what my question is what is the cheapest way to make my car faster i have a 2004 pt cruiser gt atx
it has the following mods
cold air intake
stage 1 fuel injectors
diablo pred tune
3 inch needswings downpipe
and stock srt4 exhaust from an neon
But that's what i got for the performance wise what would you guys recommend thanks guys
Midnight Cruiser
Old 23 Apr 2014, 10:48 am
InfernoGT's Avatar
Default Re: Make it faster
If you want the cheapest, you may not like the answers you get
Cheapest=Nos (Naawwwwws)
2006 PTGT with 5spd. ~60k miles
Old 23 Apr 2014, 11:05 am
What does that mean? 2004 already came with injectors good enough for stage 1 - injector upgrade was only needed for 2003 for stage 1.
Old 23 Apr 2014, 11:07 am
cruserdad1976's Avatar
just send Nitro a pm he can answer any of your how to go faster question
am im sure there are threads on here that will explain it as well
Old 23 Apr 2014, 11:48 am
AMSOIL synthetic chemical engine and transmission fluids will help increase horsepower/torque/mpg a few percent over conventional lubes.
Old 23 Apr 2014, 12:25 pm
Any dyno testing to back up this claim? I could feel a new set of plugs easer.
Old 23 Apr 2014, 02:38 pm
Of course. http://www.sinwal.com/data/2008_motorcycle_dyno.pdf
http://syntheticoilevolution.com/dyn...yno_tests.html
Old 23 Apr 2014, 02:58 pm
If you dont want that tranny rebuilt then I would stick with stock turbo and do little things. Maybe a little more boost from a custom tune. You could hit about 18 psi on stock 2 bar sensors and so if you dont want to install/rescale and do other bolt ons then 18 and under is perfect. Im manual and im already getting into a new clutch with the stock turbo and pump. Im jusr over 50000 miles. I do spike high though and still have the 2 bar sensors so I lean out bad if I keep the boost too high.
Edit: do a boost leak test and full tune up also. I gapped my ngk iridiums to .30 because of spark plug blowout. But after all that was done the car felt totally different. You wont believe how many boost leaks youll find.
another day of boost, racingg, and a little closer to the next set of tires.
Old 23 Apr 2014, 04:16 pm
boonie2's Avatar
AGAIN ???? Way to post up that "Unbiased" AMSOIL company report
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 23 Apr 2014, 04:29 pm
AMSOIL didn't run the test. Cycle Solutions Inc. did. I thought everyone knew chemical synthetic oils produced more horsepower than conventional oils. One of the reasons the pro racers use it. Here's a bunch more http://www.google.com/search?q=amsoi...ls=en&tbm=isch .
make my pt faster alx18 Tech & Performance Forum 51 01 Mar 2013 10:38 pm
faster, quicker advice needed mjsusman PT Cruiser Convertible Forum 0 25 Jul 2005 09:47 am
Faster Forums CREWZIN General PT Cruiser Discussions 4 20 Nov 2002 03:56 am
