GT Performance
Like Tree4Likes
Old 06 May 2014, 02:26 pm
Default GT Performance
I have a 2005 GT High Output Turbo and have had it clocked by a friend at the Montana Highway patrol at 138.6 MPH. This 5 speed got there in about 1/2 mile...Do I have an SRT-4 under the hood?
Old 06 May 2014, 03:38 pm
Default Re: GT Performance
Hmm there is a couple reasons why this may not be so.
But that's ok you can claim it.
Old 06 May 2014, 04:32 pm
vipergts's Avatar
I know my PT will do that easily...but it ain't stock
E1 Turbo, 3 Bar Map~Tip, 888/1025cc Duster's Injectors, Stage 1 PCM, Composite Intake Manifold, Airbox Mod With Drop In, Ported Exhaust Manifold, Walbro 255, 3 Inch Catless, Poly Mounts, Blue Plate, DCR Oil Mod, DSP, AEM A/F, FM WGA, N2mb Electronic Boost Controller, Power Demon ATX, Duster's CMR Tune, E85 Powered, Cross Driiled Rotors, BTG Springs, Mopar Ground Effects Kit, 5K HID lights and fogs, LED Tails...3080 lbs in race trim.300WHP~345 Ft Lbs Torque @ 16PSI...Now boosting 19PSI, WHP And Torque numbers coming soon.
Old 06 May 2014, 04:41 pm
Tell him to take it off "out of state driver" mode.
I don't think you were going that fast - the PT has the aerodynamics of a shoe box.
boonie2 likes this.
Old 06 May 2014, 04:47 pm
cruserdad1976's Avatar
that sure is a fast speed for the PT but maybe
Old 06 May 2014, 04:57 pm
Speedo in KPH?
Old 06 May 2014, 05:31 pm
E1 Turbo, 3 Bar Map~Tip, 888/1025cc Duster's Injectors, Stage 1 PCM, Composite Intake Manifold, Airbox Mod With Drop In, Ported Exhaust Manifold, Walbro 255, 3 Inch Catless, Poly Mounts, Blue Plate, DCR Oil Mod, DSP, AEM A/F, FM WGA, Power Demon ATX, Duster's **CMR Tune On PCM Control, E85 Powered, Cross Driiled Rotors, BTG Springs, Mopar Ground Effects Kit, 5K HID lights and fogs, LED Tails...300WHP~345 Ft Lbs Torque...Headin' for the 12's...
Gee really!
There are factory set RPM and MPH limiters. Unless you go into the **PCM and enter new calibrations they can not be bypassed on a stock PT Cruiser.
If you are going downhill and hit the MPH limit you could technical roll simply by velocity and gravity passed it and get a higher MPH clocked reading
vipergts likes this.
Old 06 May 2014, 05:47 pm
how high did you personally see the speedometer go? what gear were you in?
i'm only asking because i would go 140 in a lincoln mark 8. they are governed to 130, but for some reason with O/D off they aren't governed. if you stayed out of 5th, it might be possible.
this is why people doubt you:
Old 06 May 2014, 06:03 pm
You have the same motor as a SRT-4 Neon. No governors on a SRT-4 though.
1999 Dodge Neon Coupe. DOHC 5 speed
2005 Crossfire SRT-6
2005 PT Cruiser GT 5 speed. 1 of 21 (SOLD)
Old 06 May 2014, 06:18 pm
boonie2's Avatar
Was that off a cliff !!! or a parachute drop
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Hi new guy with a few performance ??'s blackbosoPT Tech & Performance Forum 16 13 Dec 2010 08:47 pm
Performance Add-ons ilee941 Tech & Performance Forum 14 12 Dec 2010 01:37 am
Another PERFORMANCE MOD... Gary04GT Turbo Performance 17 14 Jan 2005 01:17 pm
Performance Bob Tallman Turbo Performance 7 17 Jan 2004 05:45 am
