Lots More Power Coming Soon!
  • 1 Post By vipergts
Old 12 May 2014, 02:45 pm
vipergts's Avatar
Default Lots More Power Coming Soon!
I talked to my tuner today...He said because of the ATX the PCM will not allow my car to boost past 16 PSI due to being on PCM control...He reccomends to install a N2MB electronic boost controller and eliminate boost from PCM control. He plans on updating my CMR tune with the correct parameters and raising the boost to 20~21 PSI where it should be with my setup...Mods in my sig below...Maybe 330+ WHP in my future?
E1 Turbo, 3 Bar Map~Tip, 888/1025cc Duster's Injectors, Stage 1 PCM, Composite Intake Manifold, Airbox Mod With Drop In, Ported Exhaust Manifold, Walbro 255, 3 Inch Catless, Poly Mounts, Blue Plate, DCR Oil Mod, DSP, AEM A/F, FM WGA, N2mb Electronic Boost Controller, Power Demon ATX, Duster's CMR Tune, E85 Powered, Cross Driiled Rotors, BTG Springs, Mopar Ground Effects Kit, 5K HID lights and fogs, LED Tails...3080 lbs in race trim.300WHP~345 Ft Lbs Torque @ 16PSI...Now boosting 19PSI, WHP And Torque numbers coming soon.
Old 08 Jun 2014, 11:04 am
vipergts's Avatar
Default Re: Lots More Power Coming Soon!
Got the N2MB boost box installed and set up finally...I was boosting 15.5 PSI. which was the max I could get on PCM control with the ATX. Now boosting and holding 19.5~20 PSI...Night and day power increase...Car pulls so hard now, its an amazing difference! Still have to have a new CMR tune done for the additional boost which may yield even more power. I will bring it to the dyno soon...My guess 320~340 WHP...
InfernoGT likes this.
Old 08 Jun 2014, 12:37 pm
Let's hope you have all of your mods insured properly
Old 08 Jun 2014, 01:16 pm
vipergts's Avatar
Yea, know what ya' mean...E1 can run up to 20~21 with dependability...I'm going to set up a 18PSI and a 21PSI tune with the new boost box...You can change over in 2 minutes...Duster says the setup can handle 21 once he retunes it...It went to fast to holy crap fast...E85s high octane rating loves more boost
Old 27 Jun 2014, 06:59 pm
vipergts's Avatar
All tuned and done...Holding 18~19PSI to redline which is perfect for the E1 turbo...Spikes 21~22...This setup is maxed out now...If I need more someday I will go 50 trim, but I am pretty happy...Dyno time soon...320~330 I bet 'cause its a whole lot faster than it was on PCM boost @ 300 WHP...
Old 27 Jun 2014, 07:39 pm
No dyno pics or it didn't happen
Old 03 Jul 2014, 03:44 pm
chris15's Avatar
My local CMR tuner also suggested N2MB's boost box. Did you/your tuner/whoever have any issues with installing it?
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 04 Jul 2014, 07:06 am
Aren't you worried about trans turning into shrapnel?
Old 22 Jul 2014, 08:45 am
vipergts's Avatar
Ha, Look at my sig below...
Lots of PT stuff gypsy Classifieds: For Sale/Trade 8 10 Apr 2012 01:53 pm
Grinding/rotating noise coming from left side of car when coming to a stop...help? quietcharm23 Wheels, Tires, Suspension 3 10 Apr 2011 08:43 pm
lots problems need help trippt Tech & Performance Forum 5 05 Nov 2009 10:05 pm
Lots of chrome CREWZIN Testing 0 13 Jun 2003 08:59 am
