ADJUSTMENT OF WASTEGATE ON 2003
Old 15 Apr 2004, 11:35 pm
Default ADJUSTMENT OF WASTEGATE ON 2003
IS THER AN EASY WAT TO ADJUST THE WASTEGATE ON A 2003? CURRENT BOOST IS 10LBS WITH A PERIODIC SPIKE TO 12 LBS. THE EGT INDICATES 1300 1400 UNDER BOOST AND ANY WHERE FROM 900-1200 UNDER NORMAL CONDITIONS.
Old 16 Apr 2004, 12:08 am
where you have your EGT probe hooked into?
Pre or post turbo?
Homepage:
Old 16 Apr 2004, 08:53 am
The cheapest I have seen (I have this mod in mine).
Exhaust Depot spring mod.
I bought the Specter, chromed carburator return spring set. (Got it at P#p B@ys for $5.00). I use the thin one. I get 12PSI in first, 15 PSI droping down to 14 in second, 16PSI droping down to 15 in third, 16 Constant in fourth untill the PCM opens the wastegate and BOV when I reach 128[?]
It will take you less than five minutes to install it if you use a needle nose plier. one side goes to the wastegate actuator rod in the bend, the other side hooks perfectly in an empty hole in the side of the engine head next to the airbox. I will take a picture and post it.
You can use the wider spring, but I never got the courage to test it
Ian
Old 16 Apr 2004, 02:38 pm
Ian,
I always wondered if anyone else was doing this.
culprat@sbcglobal.net
Old 16 Apr 2004, 03:33 pm
I would be very interested to see your pics of this mod!
thanks
Old 16 Apr 2004, 10:22 pm
I am runing down to the car to take the pictures... It is so simple...
I hope I remember the Image station pasword[]
Ian
Old 17 Apr 2004, 03:08 pm
Hey Ian, must be a long way down to your car and back...
Old 17 Apr 2004, 11:33 pm
If he keeps the beer in the garage refrigerator, it is totally understandable.[8)]
Old 18 Apr 2004, 02:10 pm
I only drank a few beers while taking the pictures[^]
Then, the camara didn't cooperated with me, It displayed "Card Error". Gues I clicked on something and erased all the pictures...
Yesterday I had another of my project vehicles in for performance upgrades I finished with it at 11:00PM...
Enough of excuses here are the pictures
This is where the spring hooks up in the engine block.
[img] http://www.imagestation.com/picture/...9/f8f7ef8c.jpg [/img]
Here is the other end of the spring installed to the wastegate control rod.
The kit comes with two springs. use the smaller diameter one.
I use the larger one as an instalation/removal tool, to pull the sprig from the control rod to the enfine block hole.
Ian
Old 18 Apr 2004, 02:15 pm
Not even I can see the pictures...
Click here for the wastegate side of the spring
click this one for the Engine block side of the spring
http://www.imagestation.com/picture/...e/f8f7ef8e.jpg
Ian
AGP wastegate w/o boost control strangelove Turbo Performance 13 13 Mar 2007 01:22 pm
2003 PT Cruiser Diagnostic Manual set Dalite Classifieds: For Sale/Trade 1 21 Apr 2005 10:06 pm
2003 chromed out GT for sale bluebluegt Classifieds: For Sale/Trade 0 30 Jan 2005 09:37 pm
..rear axle adjustment? earringboy Turbo Wheels/Suspension/Handling 2 03 Jan 2004 07:59 pm
New Incentives on 2003 and 2004 Models skylight PT Cruiser News and Rumors 3 15 Oct 2003 12:26 pm
